2011 Blue Pig reach...
[Closed] 2011 Blue Pig reach measurement
[#5841653]
Anyone know the reach measurement of an 18", 2011 Blue Pig? I found some numbers over on MTBR (407mm), but not sure if they pertain to the 2011 or the previous incarnation.
Posted : 09/01/2014 8:56 pm
Don't know the reach but the ETT was 597mm if that's any good to you.
Posted : 09/01/2014 9:07 pm
Yeah, got the spec sheet that has that on it. No reach (or stack) there unfortunately.
Posted : 09/01/2014 9:39 pm
Is that frame the same as a Mk1? If so I can go get a measurement if you tell me where to measure from, and to.
Ben.
Posted : 09/01/2014 9:55 pm
I think the geometry is the same as the mk1, but not sure. I have the bike and have tried measuring it myself, but the measurement is a good 20mm out from what I'd expect it to be, so I must be doing it wrong. Hence why looking for the official figure. Might take the wheels off and try it again. Apparently, for every 1 degree your floor is off level when measuring, that affects the measurement by about 1cm.
Just foung this [url= http://velonews.competitor.com/2012/05/bikes-and-tech/technical-faq/technical-faq-setting-your-bikes-up-identically_216035 ]Measuring reach[/url], so gonna give that a try.
Waiting on a reply from Ragley, but that could take a while.
Posted : 09/01/2014 10:09 pm
Haha ok!
Posted : 09/01/2014 10:14 pm
Just so you know, I'm trying to compare it to another frame, so I know if it will feel similar, or not...
Posted : 09/01/2014 10:30 pm
And the other frame is ????
Posted : 10/01/2014 2:32 am
