Does anyone have any 2010 reba team forks with the blackbox motion control?
If so, does the compression knob have indented positions (i.e. clicks through positions?)
I have this fork- 120mm travel with 20mm maxle lite and it does click through the positions (I don't have remote lockout as I didn't want it). On mine, as I look at it, it's locked out at approx 5 o'clock position and I tend to run it around 1-2 o'clock most of the time (offroad).
Just checked on my forks with the remote lockout and the compression adjuster does indeed "click".
Cool, thanks guys. 🙂
One thing that annoys me about the non-blackbox moco is that it's difficult to run the compression adjuster in any in-between setting, since it moves around too easily and you can't set it precisely without any clicking.
on such a nice and indeed expensive fork, with a damper that's basically been unchanged (ie normal motion control one) for 6 years, that's a bit sloppy if the lever still moves around. FWIW the old looking plastic/rubber compression lever on my old 2004/5 pikes didn't move (on its own, that is...) and I gave that a right hammmering!
I wonder if an extra o-ring and a dab of grease under the blue lever would help?
