Have had an annoying knocking noise coming from somewhere on my anthem for some time, finally found it, there is some slight play where the bolt goes through the top eyelet adaptor that mounts the shock to the frame.
Any 2008 Anthem owners know what I should be looking to order, have had a look on TFTuned and it seems that there are various types and sizes etc.
If you change the DU (little cylinder that the bushing pivots on) as soon as you feel the slightest movement you'll get away with not having to replace the bushing every time = saves money.
Anyway, you will also need a new DU. Buy a few so you can easily replace it next time it happens.
1) Measure the bush length whilst bush still in shock.
2) Call TF/BETD/Mojo and double check before ordering.
Hope this helps!
