2005 Turner 5 Spot ...
[Closed] 2005 Turner 5 Spot Frame - How much is it worth?
[#4940557]
Hi , i fancy building up a light 5 spot and someone is selling one, 2005 in average condition . i.e no damage but needs a respray.
They are asking £330. Is it worth that? I was thinking about £275?
Cheers 🙂
Posted : 08/03/2013 2:32 pm
What Shock and has it had new bushes/bearings?
Bush kit is around £85, so if there is a hint of play anywhere you have negotiating point.
Hth
Marko
Posted : 08/03/2013 2:40 pm
Hi Marko , its a Fox RP23 , apparently its fine and pivots ok etc.
Posted : 08/03/2013 2:52 pm
at last, a question i can properly answer!
i recently bought a 2004 (Horst Link) 5-spot frame through the classifieds here. i paid £270.00 for it. I'm not sure that I would pay more than this for a 2005 TNT link version.
the frame needed repainting, but the bearings were good. the shock was also a rp23.
my expenditure on the frame is now somewhat more and includes:-
powdercoat in RAL6027 'light green'
new metal headtube badge (bought from CRC)
new zerts (bought from Silverfish)
new downtube decals (bought from Silverfish)
new RP23 Kashima shock (bought from CRC)
Hope headset and seat collar
modified Turner chainstay protector (actually sent foc from Turner in the states)
the end result is pretty shiny though:-
Posted : 08/03/2013 5:37 pm
Is it HL or TNT? I think that was the year of change. My late 2005 6 pack is HL.
Posted : 08/03/2013 5:42 pm
04 = HL
05 = TNT
i think
Posted : 08/03/2013 5:54 pm
TNT 06 onwards
Posted : 08/03/2013 6:11 pm
My 2005 was Horst link. TNT didn't turn up till 2006. Price wise I would have said £330 is alright as this was around a £1500-1700 frame remember but if campfreddie got his for £270 then that's a definite bargain. Of course try and knock them down. For one in good nick I would pay around the £350-£375 mark so argue the point that a good spray job plus decals and postage will easy skin you over £100
Posted : 08/03/2013 7:04 pm
Considering what Halifax Filing Cabinets sell for, that's a good price.
Posted : 08/03/2013 7:14 pm
Yea its HL version. Nice job campfreddie 🙂 I was having visions of it being a sparkly blue or white 🙂 thanks guys
Posted : 08/03/2013 7:37 pm
It's pretty, but why turn a Turner into a Yeti?
Posted : 08/03/2013 9:06 pm
 lord
misssteele ive a 2005 medium in silver , fox coil sock , bearings are good , let me know if your interested
bike as it was
Posted : 08/03/2013 9:07 pm
Nice respray that.
That price seems pretty reasonable if the pivots and shock are fine. One thing I would say is that with stock valving, the fox RP can make the HL blow through its mid travel and make it feel like a dog dragging its arse on the ground just riding along. It can make it feel like the back end is heavy and not running free.
Despite this It's a great bike. I ran my 2005 from new up to nearly 2012 before bending it (and me) in a big crash which mostly killed it, but I'd probably be running it now otherwise.
Here it is in big mountain, big miles mode, sometime in 2008
[IMG] [/IMG] it eventually ended up in this spec:
Posted : 08/03/2013 9:09 pm
Scienceofficer, are the guys at Turner helping out with a replacement?
Posted : 08/03/2013 9:12 pm
No, my insurer did...
Posted : 08/03/2013 9:17 pm
ooh such pretty bikes 🙂 am trying to haggle them down to sub £300 😉
thanks LORD but i need a small for ma wee female scottish leggies 😆
Posted : 08/03/2013 9:36 pm
I should clarify. My chainstay broke about 6 months prior to me crashing. Turner had no replacement parts for a frame of that age, but STW came good. Thus, when I crashed, it was not viable to be directly replaced, hence the newer DW one.
Lovely bikes. My late 05 HL still runs fine but a good shock is a must. Pivots last for ages if looked after. Now have a TNT 5 Spot, a HL 5 Spot and a XCE in the house, and no bother from any of them.
Posted : 08/03/2013 9:44 pm
hmm, farticus what do you think the best shock would be for it?
Posted : 08/03/2013 9:51 pm
looks-wise what's the difference between a HL and a TNT? which bits are different, and how?
Posted : 08/03/2013 10:08 pm
mine 'could' be for sale.... the standover is a little tight for the wife (she's 5'2") even though the frame is an small size (recommended size is 5'3" and the quoted standover is 30" which is actually quite high).
the spec at the moment is:-
* frame as you have seen with the brand new kashima rp23 (correct tune for the horst link 5-spot)
* hope headset and seat collar
* ks i7 supernatural remote dropper post (brand new)
* fi'z'ik arione donna saddle (brand new)
* thomson stem
* fsa carbon pro riser bars
* dt swiss exm130 forks
* 2013 xt clutch rear mech (brand new)
* 2013 slx 2x10 chainset (170m cranks) (brand new)
* 2013 slx 12-36 cassette, SLX front mech and shifters (brand new)
* hope pro3 sp xc3 hubs on ztr355 rims (sub 1,500g!!!)
* hope saw 185mm front disc and 160mm rear disc
* formula rx hydraulics (brand new)
* superstar 9mm & 10mm bolt through QRs with Hope hub converters (brand new)
* schwalbe rocket ron / racing ralph evo pacestar tyres (brand new)
* tubeless valves and tubeless rim strip
i got a 'little' bit carried away putting the build together... it's basically set up as a very fast, very light 5" trail bike for smaller, lighter riders.
photo below without the dropper post (now fitted) and with silly long brake cables (currently at lbs having the hoses shortened)... the bike hasn't yet turned a wheel under pedal power.
Posted : 08/03/2013 10:27 pm
re. the shock... the horst link frames do not require the special low speed tune that the dw link versions need. this makes it much easier to by a replacement shock off the shelf.
edit... just looked through my emails from Turner in the states (they have helped me out lots in the last few weeks)
Greg @ Turner says:-
"Back in 2004 we were transitioning from a Romic coil to the Fox air shock.
The medium/medium tune will work well on your frame."
Posted : 08/03/2013 10:28 pm
Personaly I like the DHX5 coils on both my 04 5spot & 05 6pack, the original Romic coil was also good on the Spot. I tried an RP23 on the Spot but didn't like it, it just felt lifeless & harsh to me after the coil, but I guess it's all personal preferance.
Posted : 08/03/2013 10:30 pm
the big question campfreddie , how much? 😉
Posted : 08/03/2013 10:33 pm
HL frames have the pivot nearest the drop out on the chainstay, TNT frames have the pivot nearest the drop out on the seatstay
Posted : 08/03/2013 10:35 pm
through some very canny shopping about (on the new parts and nearly new parts) the build stands me in (complete with pedals which are A530 SPDs which will very shortly be customised to include pedal pins on the flat side) at circa £1,700.
it's taken weeks and weeks of research, buying bits, going backwards and forwards to the powdercoater, long evenings with the dremel removing the powdercoat from the bearing facings etc etc.
i'm not selling for a loss... put it that way. lol (i actually already have a mate who will take it at £1,700, hence not putting it in the classifieds, but he's a bloke (a short one mind) and i built this for someone who doesn't have a willy, so would love it to go to someone who doesn't have a willy (with it being international womans day and all) lol
in any respect, i hope it gives you some inspiration and i'm very happy to give you any pointers if you take on the other frame as a project... there's lots i wish i knew at the outset!
Posted : 08/03/2013 10:40 pm
crikey, thats out of my budget im afraid - im going to try and build for under £1k , mostly second hand . But it certainly has inspired me and i may just take you up on the offer of advice! 🙄
Posted : 08/03/2013 10:51 pm
I love HL Turners, my two before they retired
Posted : 08/03/2013 10:57 pm
no worries... the original plan was to build it up using bits from a giant talon 3w i built for her which would have left me well under £1k, but then i just got a bit obsessed.
* in terms of fork choice... if you are not concerned too much about weight, the rock shox pike is THE fork for the HL 5-spot. you ideally want to be running at 130mm, so a pair of shimmed down RS Revs should work well (or a pair of Fox 32 RL 130's if you like servicing them every 2 minutes). the dt swiss jobbies are awesome with a very long service interval.
* the seatpost is a 27.2mm which limits your choices if you want to go down the dropper route (i went for the ks i7).
* the powdercoating process is complicated if you are thinking of painting the rear triangle (which was traditionally raw alloy) as nothing will go back together again unless you spend lots of time grinding the paint from the various bearing surfaces (worth the effort though!)
* it's worth replacing the zerts when you rebuild the frame. they are push fit on this age of frame.
* be VERY careful tapping out the pivot shaft and then the journal bearings... they scratch very easily and will compromise the suspension action long term. you can however do the whole job without any specialist tools... just patience and care
* the turner website has a pdf download of a fantastic pictoral guide to striping the bearings down and rebuilding... essential if you are going for a repaint.
* bearing wear seems to be less of an issue on the HL frames than later DW link frames
* aside from the dropout pivots, all the bearings are the same size (unlike with the dw link), so it's easier to sort out relacements
* you can use vaseline to lubricate the zerts... this is WAY cheaper than prep-m grease etc, but is a similar viscosity (advice from mr turner himself)
* if you ask greg @ turner nicely, he'll send you lots of pink turner stickers (well he did for me!)
hope this helps.
Posted : 08/03/2013 11:04 pm
It's zerks by the way.
Turner designed the 2005 HL 5spot around a fork with and a-c measurement of 510mm. The pike breaches this by 8mm. Whether or not you like a slacker or tighter front end is going to be down to personal preference. Many people at the time preferred a lighter fork to the pike, its not the lightest of forks by some margin, but it did carry a lot of favour with heavier and more agressive riders who like both its strength and its stiff tracking. If you're small and light IMO it will be overkill - you'd get away with something lighter quite easily.
Personally, I've found found bush wear to be about the same on the DW as the HL, But YMMV because I'm heavy-ish and aggressive-ish. Again, if you're small and light, they're going to last longer. On both bikes, its the low down BB pivots that see the most wear on my bikes.
Grinding off paint can be avoided by taking the time to mask the pivot points carefully before it gets powder coated. It's much easier and less time consuming to do this than faff about with paint removal afterwards.
Posted : 08/03/2013 11:17 pm
I miss my old HL 5 spot. Man that bike was with me for 7 hard years ridden through wind rain snow sun and dust year round twice a week and never let me down.
Even after 2 years on a DW 5 spot, I still think the old HL was better. Sniff...
Posted : 09/03/2013 12:19 am
I found a DW sultan is nearer in character to my HL.
Posted : 09/03/2013 12:43 am
 hora
An Orange 5 of that era would be 250-300.
Oh and 7yrs ago it'd been 1k new? NOT todays rrp
Posted : 09/03/2013 7:22 am
wrong thread!?
Posted : 09/03/2013 7:41 am
doublepost..
Posted : 09/03/2013 7:43 am
5spots have always been over £1600 new. Paid £1895 for my XCE in 1997!
Posted : 09/03/2013 8:47 am
 hora
You are serious? Horst frames were that much?
Posted : 09/03/2013 8:56 am
Afraid so. Think the early 5 spots were £1600 or £1700, DW kashima rrp was 2200 or 2300 which is just crazy for an alu frame, made in the USA or not. This years price reductions makes them a lot more reasonable. Been big sale discounts from merlin and crc for the last few years too
Posted : 09/03/2013 9:03 am
My HL spot in 03 was £1595 list price,
Posted : 09/03/2013 10:49 am
 hora
I know ellsworths were overpriced but thought they were 'unique'..
Posted : 09/03/2013 2:29 pm
scienceofficer - what fork do you think would be ideal? I am 5'4" approx 60kg 🙂
Posted : 09/03/2013 8:38 pm
Catching up ... RP23 on my 5 Spot is great (but anything after the DHX Air would feel good).
Best I had was a PUSH'd Vanilla RCA on my old XCE ... Almost invisible performance.
Posted : 09/03/2013 10:03 pm
I've got a push tuned fox vanilla r on my HL 5 spot, with floats up front. It's just lovely I reckon I paid £1500ish for the frame in 2002/3.
Yes it was a lot of money but I'm still riding it, a lot....
Misssteele I reckon Rockshox revs would be good, or possible sectors. If you could stretch to the fox floats I ca 't reccomed them enough
Posted : 09/03/2013 10:14 pm
Know it's not a 5 Spot, but (IIRC) my 2006 TNT RFX was £1700 when I bought it new. Must get it built back up sometime seeing as it's currently chucked in a corner of the spare room...
Posted : 09/03/2013 10:27 pm
Misssteele - I think you'll get away with pretty much anything at that weight. as a 14 stoner, I'm not really qualified to comment!
Posted : 09/03/2013 10:32 pm
