Hey,
Just fitted some 2003 Marzocchi Z1 Drop Offs to a small Chameleon and noticed that the lock-out switch is going to hit the bottom of the frame. Any suggestions? I though fitting a headset with a larger crown may help.
Spacers under the crown race, or chop the lever off?
Hey,
Can you put spaces under the crown race? I've just taken the lever off and it goes under the frame ok. I would prefer to be able to leave it on though as otherwise I can't turn the ETA on.
Thanks
On my old ETA forks the lever turned a small shaft, which was easy enough to turn by hand even with gloves on.
Hey,
Decided to go for a Hope headset and most likely file the lever down.
Thanks for the replies.
take the lock out off. 2mm allen key iirc
Cool thanks. BTW where do most people here service their forks?
dunno 🙂
