I've got a set of Fox Float 32's with post brake mounts. I'm after fitting my older style M4's (black and Gold) which are IS mount (180mm caliper). If I use the post to IS adapter, do I want a 200mm or a 203mm disc (or will both/either fit) ?
Michael
200mm for IS caliper, 203mm for post mount.203mm may fit, but will be very close to touching the caliper, some do, some don't.You could space it with a washer if you've already got a 203, but if buying one you may as well get the correct one.
hope do a post mount fork to IS caliper mount which needs 20mm bigger disc its on here
http://www.hopegb.com/voir_ADAPTMANAV.html
i have a 6 month old 200mm disc if your interested little use
