20 seconds gap on a...
[Closed] 20 seconds gap on a 60 second trail
belugabob - Member
I wouldn't necessarily blame Strava - it's more likely to be the accuracy (or lack thereof) of the GPS device used to record the ride,
I'd blame Strava for the lack of quality control tbh. I mentioned up the page the KOM on the Bitch at Glentress, it's a good example. If I look at my traces, you get 30-40 GPS plots from top to bottom, mostly pretty nicely in the shape of the trail. If you look at the KOM, you get 5 GPS plots and the first one is about 75% of the way down the trail. It's just not a succesful logging of the segment.
There's a level of reasonableness, Strava can't tell if you cut the corners halfway down which is worth a good few seconds, but it can tell if the GPS plots are too infrequent, or too far from the real track, or in this case nowhere near the actual start of the segment...
So yes, it's the GPS data that causes the problem but it's Strava that accepts such useless info. They seem to have faced the decision of accepting rubbish and getting bad results, or being discerning and accurate which would probably lead to unhappy punters going why didn't my time log, and a lower number of succesful segments which probably makes them look less omnipresent.
It does seem to be better than it was- when I started using it, it'd often log segments you'd never ridden just because you rode past the entrance, it now seems to look for some plots within the segment too.
None of this makes it useless, you just have to take everything with a huge pinch of salt.
Posted : 01/03/2016 11:09 am
Yes, vertical is pretty far out between a Garmin and iPhone. Makes a mess of all the other power/calorie-related stats too.
Posted : 01/03/2016 11:11 am
The KOM and runner-up on one of my regular local segments was ridiculously quick - 3mins up on some seriously fast riders (not me, I hasten to add). Was prepared to accept this until I noticed that one had titled the ride 'Argo to work'. 😀
I can put up with being 3 mins down on the leader, just not six minutes on an eight-minute segment!
Posted : 01/03/2016 11:13 am
Why not report it then?
Posted : 01/03/2016 11:15 am
 br
I live/ride in the Tweed Valley, ever heard of the EWS?
One of the sections this year was Repeat Offender (top, middle, bottom), Greg Callaghan is sat at KOM on 3mins 57sesc (1 mile and nearly 1000ft of descending).
The fastest of the guys I ride with is at 5mins, and I'm past 7mins..., but still in the top half...
https://www.strava.com/segments/8228187
As said previously, the fast boys/girls aren't riding the same trail as us really.
Posted : 01/03/2016 11:18 am
We have a local pro who checks any kom's and flags ones where people are faster than he thinks they should be.... Must be great to have enough time...
Lol about the ews, https://www.strava.com/activities/497460542
JG53 seems a bit quick...
Posted : 01/03/2016 11:24 am
Professional cyclists in going faster than average punters shocker! 😆
Re. strava, gps etc. Its the same as any measurement, there is an error associated with it, given that strava (for most people) isnt life and death. it doesnt matter. Sort segments just compound the error. I tihnk phone GPS has a positional accuracy of approx 10m so for a 250m segment, someone could have ridden 230m and anoter 270m, thats 16% differnece in distance comapred to the actual segment. Hardly surprising times are off!!
molgrips - Member
Because it's not a one off bad result- it's one example on one segment that shows why Strava doesn't really work. I [i]could[/i] go through every segment I've ever ridden and manually report every dodgy time, but I'd not get very far before I went on a killing spree so instead I just go "Meh, strava's pretty broken isn't it" and use it within its limitations.
Posted : 01/03/2016 11:26 am
I just assume anyone going faster than me has a dodgy GPS device, takes EPO, or rides and e-bike !
Posted : 01/03/2016 11:27 am
A few years ago i took Steve Jones (dirt), Stu Thomson (cut media), Joe Barnes and Liam Moynihan (Dudes of Hazzard) round Kirroughtree and elsewhere in the area for a Dirt mag photoshoot, whilst i thought i was pretty decent and [i]fastish[/i] rider (could comfortably lap kirroughtree in under 2hrs on my SS) their riding showed me up for the wannabe mediocore mtb'r that i really was 😥 .
It wasn't so much their fitness that made the difference but more so the speed they could carry through sections and out of turns/berms, on some areas of the trail where there was a climb or a pretty much straight through section i could comfortably keep up with them but as soon as became really tight n' twisty with tricky rock or severe off camber rooty sections sections they just left me for dead despite me having "local knowledge" having lapped Kirroughtree literally hundreds n" hundreds of times (my local trail).
It was a genuine eye opener getting to ride with them for a couple of days and seeing how the genuinely fast folk can gain a second, or two, or three (or tens of seconds) 😥 on a relatively short section of trail.
Posted : 01/03/2016 11:35 am
Yep it's mainly about the corners, I reckon.
Posted : 01/03/2016 11:38 am
I usually ride with a Garmin 800 and my times on Segments are pretty consistent (slow), but I'll occasionally forget the Garmin and use the Strava app on my iphone. Whenever I do that I always seem to get PRs on random segments (especially ones with decent tree cover).
It's all just a bit of fun though.
Posted : 01/03/2016 11:49 am
It works fine as you say within its limitations.
Posted : 01/03/2016 12:22 pm
If it makes you feel any better I'll come and ride it at least 20 seconds slower than you.
Posted : 01/03/2016 12:28 pm
I think these are my favourite threads
On such short segments strava is massively inaccurate, the time can be greatly shortened if the first and last gps points are a good way into the segment, which can be pot luck, tree coverage or from your device settings. If you really want to have a good time on it, just finish your ride at the bottom of the segment, and crop your ride. Strava will let you crop it a surprisingly long way up the segment and you can shave a good bit off, and then feel really great about your strava result, which is the most important part of mountain biking.
But a genuinely fast rider will pump 99% of stw mincers who think they're ok, I ride with a fast guy and it's hard to get your head round it. It's good fun to watch your group on strava flyby though with one dot shooting out in front.
Posted : 01/03/2016 12:35 pm
Our local Strava hero/ obsessive / saddo (delete as applicable) records on his Garmin and his phone, uploads both and takes the 'best' one for his KOMS, deletes the other
Posted : 01/03/2016 12:37 pm
molgrips - Member
My riding works within its limitations but it still leaves me embedded in the occasional tree. Everything works fine within its limitations if you accept "doesn't really do what it's supposed to do" as a limitation. But I'm not a project manager so that doesn't really sit right with me.
Posted : 01/03/2016 12:44 pm
 bubs
bigjim - this was not about being a Strava hero, this was about how someone can be so much faster i.e. how can I get faster/better.
I think chakaping has it with corners. This trail has quite a few steep, rooty switchbacks which I possibly may not be tacking quite rightly.
My other bike is a rigid singlespeed and so Strava really is a tool for me rather than a member extension device.
Posted : 01/03/2016 12:45 pm
the fact you know this suggests he's not the only one...
Posted : 01/03/2016 1:21 pm
Try living near ...
Phil Pearce (World Cup XC racer) owns our local trails!
Posted : 01/03/2016 1:56 pm
My local trails have been Sam Hilled. Well they are his local trails as well, and he was here first but still. Brutally fast. I have absolutely no idea how.
No shame in being beaten by the best.
Is Mike Jones far behind him or is he not on Strava?
Posted : 01/03/2016 1:57 pm
If I'm more than 30-40% up on the KOM I'll stop halfway down and learn a dead language or make a couple of hundred metres of coir rope out of decency.
Posted : 01/03/2016 2:01 pm
 D0NK
perusing my commute home last night showed how daft it can be, from when I switched on to about 15mins in the route was all over the shop, really badly zigzagging where I had taken a straight line, had me doing segments on the road when i was riding the canal. Later on in the ride it was really accurate, enough to show which line I took in some parts.
Like northwind said, strava seem happy to accept crap data* and while you know that's happening you really shouldn't be taking it seriously**. Look at any segment where someone has whipped you, could be a stellar rider, could be someone with similar abilities in pefect conditions putting in a PB run with a massive tailwind, or it could be a slow numpty with a crap gps unit, you'll probably never know.
*that's on top of head/tail wind, mud, trail creep, traffic,etc all making [b]big[/b] impacts before you look at timing quality
**not that you should be taking unofficial "racing" seriously anyway
Posted : 01/03/2016 2:02 pm
I always take Strava leaderboards with a big pinch of salt. I follow a local xc endurance mtb rider who I use as my benchmark for times (read as target) if I can get anywhere close to his times I'd be very happy,
In reality I'm considerably slower but keep getting marginal improvements which is all I'm after and the main reason I use Strava.
Posted : 01/03/2016 2:19 pm
If you care, you should look at their other segments and rides and see if it looks legit.
Posted : 01/03/2016 2:45 pm
my comments weren't aimed at you, just in general, I'm just always amazed at both how seriously people take strava and how much faith people put in it's accuracy, especially on short segments when the whole thing could be based on a few gps points.
I keep meaning to do a test of the height gain calculation from strava too, I think I can get my hands on some decent data to use so just need to work out the methodology.
Posted : 01/03/2016 3:26 pm
I know short segments are more vulnerable to error and Strava sometimes freaks out a bit, but my experience is that if I [i]feel [/i]I've gone quicker on a sub-minute section - I usually have.
In other words, I'm constantly surprised by how accurate it appears to be.
And while I don't study everyone's profile, the gaps between myself and better riders usually seem consistent and credible.
Posted : 01/03/2016 3:32 pm
Strava falls down when you've got adjacent fire roads or other trails, excessive shortcuts (not Strava lines, they've always occured) or excessive tree/leaf cover (which screws up the GPS). But it's pretty accurate otherwise.
Regarding faster riders being a lot faster, I think a bit chunk of it comes down to MTBs not having engines. Once you lose speed it takes a lot of time or energy to regain. If you carry speed round a corner or over a jump or drop, you end up with a virtuous circle all the way down the trail. It adds up really fast. As soon as you take a feature slower than is possible it impacts not just that feature but dozens of yards more trail (depending on how steep/fast the trail is). And if you stall, like screwing up something technical or skidding/squaring off a turn, you lose even more time.
The Strava comparison tool really shows this clearly. This was the highpoint of my weekend's riding yet I'm a similar amount per minute behind the KOM: https://www.strava.com/segments/6646217/compare/MTIxMjM1NDEwMTEsMzYzMDMxMjg2Mw==
The biggest loss in time was failing to carry speed around that right hand switchback. And despite being 40 seconds behind the KOM I was over 2 minutes quicker than the median rider (out of 4000+). I've seen what Pat CJ can ride like - he's bloody quick, in a way that I can barely understand let alone attempt to do.
As an enthusiastic and reasonably quick 30something amateur I know I can ride a bike downhill fairly quickly compared to a newbie - but there are tons of amateur DHers, enduro racers and XC racers with amazing skills and fitness who aren't much slower than the pros, and the pros are so much faster than someone of my mediocrity could achieve. I've very much enjoyed seeing how the winning riders demolish the stages on the races I've entered - they see the trail in a completely different way, carrying far more speed everywhere.
Posted : 01/03/2016 6:02 pm
Not read the whole thread but in answer to the OP... I am guessing it was DM, if so the fact is he is fast.
I often catch people on segments when I have left huge gaps... get to the bottom and they are buzzing from their run. For balance I have been caught by guys when I have been going flat out for me.
The gaps in ability and fitness can be huge.
I tend to pick a guy who is say 10% quicker than me on Strava and then work at narrowing the gap or catching his times... it is just riding but I enjoy the challenge.
Posted : 01/03/2016 6:04 pm
Page 2 / 2
