20% ish hills in th...
[Closed] 20% ish hills in the Peak
[#5501324]
road hills - where are some good uns?
Posted : 09/09/2013 9:13 pm
Are you just looking to tick off some classics or stringing a route together? Winnat's Pass is an obvious contender, with some great surrounding roads to build into a route. However if you want something quieter and less obvious, you could do worse than head into the Staffordshire Moorlands. Plenty of little gems there.
Posted : 09/09/2013 9:20 pm
Sydnope Hill, Two Dales (B5057)
Few little back roads round here to choose from as well:
[url= http://streetmap.co.uk/map.srf?x=407338&y=381270&z=120&sv=407338,381270&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=621&ax=407338&ay=381270&lm=0 ]Chapel-en-le-Frith[/url]
Posted : 09/09/2013 9:22 pm
...and all those Crazy Legs mentions.
Had you posted a day or two earlier, you could have ridden yesterday's Leek CC Legbreaker [url= http://www.leekcyclistsclub.org.uk/ ]Clicky[/url]
Posted : 09/09/2013 9:25 pm
There's loads with short sections.
Coombs to Castle Naze will give you some 30%+ bits.
Posted : 09/09/2013 9:28 pm
That looks good and starts 200yds from my house.....no route though? If you're keen Rob J I'll happily join you? I'm very average but have done a few Sportives ..... Cakes and coffee my speciality ;0)
Posted : 09/09/2013 10:03 pm
I'll try pop in on the dog walk tomorrow and see if I can get some route info.....
Posted : 09/09/2013 10:04 pm
Bank Road, Matlock
Posted : 09/09/2013 10:09 pm
Around Macclesfield, follow the Route 70 signs: Blaze Hill out of Bollington then the aforementioned Ankers Lane up from Lamaload Res a few miles later. Cross straight over the Cat & Fiddle road and run along Wildboarclough Valley. Hang a right up through Sutton End and that's three good ones in less than 10 miles. You could loop back and do that Macc Forest climb too; that route up through the forest on Toot Hill is a killer.
Posted : 09/09/2013 10:20 pm
It's West Yorkshire you need to come to mate, 20% round here is average. 🙁
Shibden Wall to start you on, then head off down to Keighley then the Calder valley to finish you off.
I drive down a lot of out of the way roads round these parts for my job and I went down a road which was cobbled but at the bottom was so steep I had to have 3 goes getting round it as I thought I was going to ground the car.
Posted : 09/09/2013 10:24 pm
Strines road heading A57 towards Langsett the 2nd hill (Ewden Beck, I think) - some other short 20% sections in the Ewden area including the road from Lower to Higher Bradield
Pea Royd hill out of Stocksbridge is in Simon Warren's book as having 20% sections
Posted : 09/09/2013 11:18 pm
Gorsey brow, broadbottom.
Riber road Matlock.
Posted : 10/09/2013 12:00 am
Winnats pass. Killer.
Posted : 10/09/2013 6:40 am
I'd check with Mike at Peli Deli as to which route they're doing, and how hard it'll be. The start venue and ride description are different on the official leaflet, too:
Posted : 10/09/2013 8:04 am
Different date too.......
Posted : 10/09/2013 10:46 am
