Just been Youtubing (in light of other main problem) and it would appear that if your bike has the clamp style front mech then the BB needs 2 spacers.
I do not think this is the route of my main problem as bike never has had 2 spacers..just the one.
But, is this info correct?
My choice of the number of spacers (2 on one side, 1 on the other) was determined by the length of the axle on the cranks. Would love to be able to get rid of the 2 (non-drive side)
1 driveside for a 73mm bb shell, 2 driveside and 1 non-driveside for 68mm bb shell. 🙂
Do you mean an 'e-type' mech? If so, you wouldn't use a spacer at all on a 73mm shell and only 2 spacers (1 drive side and 1 non drive side) with a 68mm shell.
or two driveside if you have blackspire stinger interfering with chainrings.
How about if u had a 73mm bb shell & a bb mount stinger .... Say... On an orange 5 with raceface cranks... What would you do then?
I have two drive side, none other side, bullit with stinger, seems to work fine don't notice any issues.
edit: just seen you have a bb mount stinger, dunno but try and put as many as you need between stinger and bb to give clearance.
Usually I'd say the same as a BB Mount Mech (e-type), which would mean no spacers on a 73mm shell - but never used one so couldn't be sure?
All you need is here....
ALBASH82...... you would use this stinger instead of a standard stinger 🙂 : http://www.chainreactioncycles.com/Models.aspx?ModelID=40530
