1x9 - Middleburn RS...
[Closed] 1x9 - Middleburn RS7 Uno as front ring - ok?
[#1651783]
Thinking of going 1x9 on my current singlespeed. It currently has a Mburn RS7 sq taper crankset with 32 uno ring.
Question is 'can i use this crankset on a 1x9 setup?' When looking at these cranks on CRC it seems to suggest that they can only be used with a dedicated singlespeed chain. I'd obviously need to change the chain and was thinking of using a standard SRAM one. Would this be ok?
Can anyone help?
Thinking of using the MRPx.1 chain device as well. Anyone have any thoughts on these?
Thanks in advance...
Posted : 28/05/2010 11:37 am
can't see why not
you'll probably need some sort of double sided chain guide so you don't loose the chain on the front all the time though
something like [url= http://www.stif.co.uk/gear/select_options.asp?productid=1094&store=mtb ]one of these[/url]
I'm sure there are some neater ones than that but can't remember what they're called
Posted : 28/05/2010 11:40 am
Getting the chain aligned with the guide could be a problem. I have sq-taper RS7s with a regular spider and ring and had to put washers on the chainring bolts to shift the chainline in about 2mm. It works ok, but can jump occasionally shifting to the lowest gear.
That was with an e.13 XCX but the MRP looks about the same, though some have said it has more adjustment. I'd look a a Paul's Chainkeeper if I was doing it again.
Posted : 28/05/2010 11:54 am
The Uno chainrings are available in two widths, for singlespeed chains and nine speed chains. If you have the thicker one then it won't work very well with a nine speed chain.
Posted : 28/05/2010 12:12 pm
