1x11 And steep h...
[Closed] 1x11 And steep hills
@onzadog Just how many times do you use your current bottom gear? On my previous bike (26" and the then standard 3x9) it was very rarely so I haven't really noticed "the loss". I can get up "most" of the hills here in the Dales, the ones I fail on tend to get rocky at the same time as I run out of oomph. Getting off and walking a hundred metres or so isn't really an issue.
I see that SRAM are promoting a road 1x drivetrain.
Posted : 17/06/2015 9:52 am
I tried 1x10 for a few months on a HT 29er. I had 11-42 with a 28T chainring. It worked fine and wasn't much worse than a 2x10 setup, but it was still a bit worse and I couldn't really notice any advantages. I don't find front mechs hard to setup or maintain and the weight saving is too small for me to care. So I went back to 2x10. In practice I very rarely use my 22x36 gear, but when I want it I really want it.
Having said that, it's worth pointing out that going up a given slope at a given speed requires you to produce the same power regardless of the gear you are in. Pushing a bigger gear (at a lower cadence) requires more force (i.e. bigger muscles) but the same power. If you ride the bigger gear for a while you will build up the muscles (just try not to blow your knees out in the meantime).
So, I wouldn't be put off a 1x setup if there were some advantage that I cared about (e.g. some full suss 29ers can't run a front mech, so if I wanted one of them I'd live with 1x) but I wouldn't bother ditching a perfectly good 2x setup.
Posted : 17/06/2015 11:42 am
I like, and use my granny gear.
On my 650b I regularly winch myself up local climbs on 24/34 which is around a 19.5" gear.
On some loose surfaces, with steep, prolonged ascending, I would loose traction or fatigue.
Works a treat at the end of a long ride when faced with a steep climb.
All horses for courses with lots of variables: cadence, gradient, leg power etc.
I do like the clean lines of a single NW chainring up front though.
Posted : 17/06/2015 11:55 am
@whitestone, I use it a lot. Whinching a 36lb 160mm dual suspension up hills in the Peak district can be hard work. The road climb at the bottom of Snowdon from llanberis, I used it there as well.
Posted : 17/06/2015 12:03 pm
@onzadog
Fair enough, I've found that as I've got used to the range of the 1x10 I've looked for it less and less. I used the 40T a reasonable amount at first but now could probably either drop it or go to a 32T at the front.
That climb out of the village is a b**ch!! Never liked it when walking up to Cloggy (big crag off to right) when I used to climb.
Posted : 17/06/2015 12:43 pm
I must be soft!
26" hardtail has 30t and 11-42
Might try a 32t as I'm running out of gears at the top end occasionally, but I wouldn't want to go lose much more than that at the low end as I'm using 'em all.
I find it roughly equivalent to my 26" 2x10 (24t granny) 11-36 for climbing ability.
Posted : 17/06/2015 12:53 pm
The thing is too, it's not so much about making it up, sometimes 1x means you still get to the top, it's just much less fun, or much more tiring. I figured out at the glentress seven this year after a few laps that I was faster pushing up the unpleasant bit of the climb then riding the next bit of the climb faster, than I was burning the legs to ride it. Might still have been the case with a granny ring to be fair. But forcing your way up a climb can take it out of you.
Posted : 17/06/2015 12:56 pm
Been running a 30t for winter but now we are in the midst of the HK summer I'm on the verge of dropping to a 28t for month or so, I'm no great climber at the best but trying to get up 300-500 meters in 35 degree heat and with 80-100%% humidity hurts.
Posted : 17/06/2015 1:09 pm
There is no need for guessing, the overall gear can be calculated as inches traveled per crank revolution. I am going from a 26" wheel 2x9 setup to a 27.5" 1x11 so I wanted to figure out how it compared before buying.
My existing 9spd cassette goes from 11-34t with 22/34t chainrings. This gives a low gear of 52.9 in/rev which lets me spin a nice cadence up steep hills. The new bike is 10-42t cassette so I will need a 26t chainring to get closest to that gear with 53.5 in/rev. Luckily the bike comes with a Raceface Turbine direct mount crank and can take a 26t ring ok.
The next question is what do you lose by going to a small ring. The old bike went up to 252.5 in/rev in top gear and 213.6 in the second smallest cog with big ring. The 1x11 will do 224.6 in/rev in top which is pretty close to my old second-from-top gear. I find that I *VERY* rarely spin out top gear so thats no big loss to me, however I am often spinning the smallest gear up hills. So 26 tooth it is 🙂
Posted : 23/06/2015 1:25 pm
On 26" I really like te AB 32 and 11-36 except for the knee pain which starts after 2 hrs. Going back to 32/24 & 11-36 setup for longer rides.
Posted : 23/06/2015 2:06 pm
My bike is 34:20 with an 8spd Alfine, old hat 26".
Really don't miss the lower gears although my other bike is a singlespeed so I suppose I've forgotten what a proper spinny gear feels like. The singlespeed as taught my legs/brain that its OK to stand on the hills occasionally and if it were geared any lower, I might as well just walk, it'd be no slower 🙂
According to Sheldon, my set up is approximately the same as 32:30.
Posted : 23/06/2015 2:24 pm
Page 2 / 2
