1x10....can't ...
[Closed] 1x10....can't set it up. Help!
[#5365137]
36 cassette. 32 chainring (installed where middle ring should be on chainset.
SLX Medium cage shadow +. New chain. Hope jockey wheels.
It clicks on the bottom jockey wheel when in 1st/2nd gear. B adj & high/low are set properly. What's going on?
Posted : 25/07/2013 1:57 pm
Have you set the angle adjuster properly?
A recent indexing problem on my bike was caused by this being out by 1/4 of a turn.
Posted : 25/07/2013 2:04 pm
Cable tension?
Posted : 25/07/2013 2:05 pm
New chainring as well? Old hooked chainring will make the mech wobble around as the chainring fails to release at the right time.
Posted : 25/07/2013 2:09 pm
Thanks guys.
What about the jockey wheel. The lower Hope one 'clicks' as each link goes over it. It's trying to pull the link central. I wonder if chain line has out to do with it. It's a Cotic soul and I've got a spacer on the BB. Would removing it make any difference?
Posted : 25/07/2013 2:11 pm
Have a look to see if the middle ring lines up with the centre of the cassette, between 5th and 6th cogs on a 10sp. Yours may be heading towards the smaller cogs so the angle to the big cassette cog is too great.
Although you should in theory be able to run a big ring to the largest cog on the cassette which would be further out anyway, so this might not be it.
Posted : 25/07/2013 2:23 pm
Slightly twisted gear hanger?
Posted : 25/07/2013 5:09 pm
Worn chainring surely?
Posted : 25/07/2013 7:46 pm
Stiff link?
Posted : 25/07/2013 7:48 pm
It was a short chain. User error. All sorted now. Thanks
Posted : 26/07/2013 3:05 pm
