Do I ditch the bash or leave the cranks bare?
Got a renthal ring on a blue frame but forgot it would mount on the inside so won't look as good!
Ignore this post - drink has been taken
Next time ill engage the filter between idle thought and keyboard entry
if you've been drinking then at least disagree with yourself for our amusement.
FWIW i think a blue frame should only have a renthal ring mounted on the outer side of a chainring, if it will only mount on the inside then you will have to either buy a new frame or spray it a different colour.
Y'see - that's what I think too
I was considering the impact on chain line and tension etc on a brand new clutch mech as I've done it with a red chainring on a white singlespeed
Forgot to mention its an old deore triple crank so you won't be able to appreciate the full glory of the blue frame and the anodised gold ring
Might have to get new cranks...
So no more drink
More drink and keep posting 😛
What colour cranks for a blue frame and anodised gold chainring?
And more to the point how much less will it weigh if I polish the cranks?
