1x10 (Shorter) Chai...
[Closed] 1x10 (Shorter) Chainring Bolts
[#5097216]
Could somebody tell me what length replacement chainring bolts I'd need to swap from a 3x to a 1x set up.
The chainring I'll use is a Hope IBR & Shimano FC-M552 chainset if it makes any difference.
Preferably available on CRC & black.
How about these or is 10mm too long?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40501 ]Clicky[/url]
Posted : 24/04/2013 8:46 am
Not CRC or black, but [url= http://www.charliethebikemonger.com/id-cromo-chainring-bolts---single-speed-double-and-extra-large-128-p.asp ]Charlie The Bikemonger[/url] does the short ones for single chainrings for only a fiver
Posted : 24/04/2013 8:54 am
 cp
The ID ones as linked on CTBM amongst other websites are great - basically you just want a singlespeed/single ring chainring bolt. Loads of options out there, choose your price!
Posted : 24/04/2013 8:55 am
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=19227 ]Available in Black from CRC[/url]. These are the correct ones - the reviews indicate they have been used on single speeds
Posted : 24/04/2013 8:59 am
http://clee-cycles.co.uk/esite/P912/product
Posted : 24/04/2013 9:00 am
I remember reading in a review that the Hope IBR rings come with specific chainring bolts. Might be worth checking as single ring bolts are at least £10 for 4.
Posted : 24/04/2013 10:05 am
File your existing bolts down to fit.
Posted : 24/04/2013 10:16 am
Thanks all for being so helpful!
Simon - I'd like to keep the original ones incase I need to swap back to 3x or 2x
The single speed ones on the CTBM website are out of stock at the moment.
I only said I'd prefer CRC is because my shopping kart is at £68 and I think I can use one of the codes to subtract £10 if I was to spend £75.
I'll try to find out if the hope chainring comes with the bolts!
Thanks again
Posted : 24/04/2013 3:14 pm
Yea the Hope IBR Doesn't come with the shorter chainring bolts apparently.
Posted : 24/04/2013 3:48 pm
 cp
ID ones also from Evans
http://www.evanscycles.com/products/id/single-chain-ring-bolts-ec006126
Posted : 24/04/2013 3:56 pm
You wont 😉
Posted : 24/04/2013 4:14 pm
I went for [url= http://www.leisurelakesbikes.com/p/2829/id-alloy-chainring-bolts-set-of-5 ]these[/url] in the end.
Thank you all for the help and advice!
Posted : 24/04/2013 4:23 pm
Charlie The Bikemonger does the short ones for single chainrings for only a fiver
+1 these are good
Posted : 24/04/2013 4:44 pm
 gamo
Just used the black xt torx one's that were on the chainset and worked fine.
Posted : 24/04/2013 4:53 pm
