1x10... Shorten cha...
[Closed] 1x10... Shorten chain?
[#5625306]
Going 1x10 ..do i need to shorten chain from a 3x10 FS bike setup.. Or still apply chain to biggest cog + 2 chain. Cheers.
Posted : 22/10/2013 2:39 pm
You will need to shorten it (or should at least). Still do chain round chainring and biggest sprocket with the suspension compressed and add 2 links rule.
Posted : 22/10/2013 2:40 pm
Suspension compressed.. You mean fully empty air in the can right? Cheers.
Actually changing it to med cage, as i have one lying around.
Posted : 22/10/2013 2:41 pm
Yup. It can be the difference between ripping a mech off or not with some bikes.
Good call on the mech.
Posted : 22/10/2013 2:43 pm
Yeah, stick it in the biggest cog, cycle it through the suspension, no better way and no reason to do it a worse way IMO...
Posted : 22/10/2013 2:59 pm
I didn't know you had to compress the suspension...I did overlap an extra 2 links tho to compensate for snappage (the possibility of)...
Will I die?
Posted : 22/10/2013 3:31 pm
How is the position angle of the rear derailleur when fitting the chain by the way? ..i dont know how to describe it in words, but you know what i meant.
Posted : 22/10/2013 4:25 pm
[url= http://m.pinkbike.com/news/Tech-Tuesday-Chain-Length-Basics-2012.html ]Pinkbike article on chain length.[/url]
Posted : 22/10/2013 5:01 pm
Good that. Esp the pictures. It should look like this in big-big:
Posted : 22/10/2013 5:38 pm
Cheers for the link and photo. Appreciate it 😉
Posted : 22/10/2013 6:18 pm
