I definitely don't spin while i'm chatting. I'm aiming to avoid anaerobic exercise as much as possible, that's not fun at all!
Ideally the funnest downhills are steep so don't require a great deal of pedaling.
Oh, are you all lycra [s]lords[/s] types?
George! 36T and 32-11 is a struggle around our doors..... Granny is there just incase ;)Clutched mech and front derailleur keep the chain in place. Why tamper with the unbroken?
you cant get away with 1x10 in swinley forest 😉
So next to nobody seems to ride like me then.
I gave the example of the Honister zigzags as I doubt lots could even get to them, a limiting factor is keeping the front wheel on the ground and it is one of the hardest climbs I have attempted that most people will know about. I also admitted failure. Techy climbs tend to fail for me due to rock steps and roots. Is it hard sitting down spinning to move your weight around to unload your front wheel. One reason why road racers may not straight away clear mountain bike climbs, one needs a bit of body language.
Cannot think of much on Simonside that I can't do due to too higher gear range, but then I would not choose to climb up the burn and take the red route on which the only bit I can't climb is the rocky steps before the tree line.
I agree that higher gears do not always mean higher speeds. I have a commuter with an Alfine hub and put a big ring on the front but experimenting spinning is usually just as fast as getting in the big ring.
I live and mostly ride in the White Peak. A mate used to beast me up climbs on a Spesh Big Hit with a single ring whilst I spun away in a granny gear. He was happy, I was happy.
Whatever suits.
He now races DH in Nationals, but that's an aside
Where can I get one of these fancy cassettes been struggling a bit lately getting up the hill to my house
[URL= http://i199.photobucket.com/albums/aa46/amticoman/IMG_2580.jp g" target="_blank">
http://i199.photobucket.com/albums/aa46/amticoman/IMG_2580.jp g"/> [/IMG][/URL]
[url= http://www.oneupcomponents.com/ ]http://www.oneupcomponents.com/[/url]
i'm going 3x10 with one of those^^ 😉
Front wheel traction may be increased by sitting with your butt forward on the nose of the saddle, upper body dropped towards the bars... in order to achieve that, the range provided by smaller front and 10-42T rear makes an overwhelming amount of sense.
Standing and driving the pedals while reefing backwards on the bars to generate the required power and torque probably isn't the best way to tackle a long steep climb if you want something left for later.
You obviously have a good level of fitnes and strength, so it would be interesting to see how you get on with a 42T rear on that challenging climb you mention and swapping your power approach out for a little more cadence afforded by a wider range cassette and I bet you could get a whole lot further up the climb. (never seen It so I've no idea what it looks like)
different people approach tech climbs differently.. when I used to run a 3x setup, I literally could not get up anytghing technical in granny.. I needed middle ring due to my momentum/power 'technique'. Others have different strength characteristices that mean more granny spinning up tech works equally successfully for them.
I'm running 32t - 11/36 and that works for everything here for ME.. except racing.. I'm not fit enough to carry that ratio spread for more than 1.5 hour races, so for the numerours 3+ hour races with significant climb sections, a 42t rear would be the difference between successful enjoyment and absolute self destruction.
The biggest downside of 1x10 that I've found is low traction situations- snow, sloppy pervasive mud etc. Far more likely to break traction if you lack the lower, spinnier gears. I ended up converting one of mine back just for this reason, it's the official Bad Weather Bike and removing the granny knackered it for that.
Who actually spends their time and money to take a mountain bike to the Alps to ride UP the hills when there's a fantastic lift system that lets you get in far more of the fun stuff than you ever would otherwise?
Me and lots of other people. In my experience the best bits of singletrack are nowhere near any lifts 😉
I love my 22x36 supergranny gear 🙂
Last time I rode that was with a load of Lakes abnormals, you know the type, they have never been to a gym, their energy food is guinness and mars bars, their bikes are completely pikey but they are fitter and harder you will ever be. All 12 of the group got to the zig zags (after completing half the Borrowdale bash from keswick), then 4 more cleaned the climb and 2 were girls. We then completed the the next 30k of the ride with tonnes more really steep tech climbs.
They all had granny rings, except the oddball on a singlespeed.
Get the picture?
I went the other way starting in Loweswater, Scarth Gap, Blacksail, Styhead, Fleetwith Pike on a patriot with a granny ring. I was knacked and pushed the last bit but blasted Warnscale. You get the picture.
I think that's another thing that depends upon your physiology and skillset - in a higher gear you have less torque multiplication so it should be easier to avoid wheelspin, which is the opposite of what you're saying. What would counteract that is if your legs aren't so good at providing even power impulses at lower cadence and higher pedal forces. The big cassette sprockets to a middle ring ratio works better for me in slippery conditions than the handful of even lower gears available with a granny ring as I can provide longer smoother power impulses at the tyre.
I think the true picture is either:
1. Some people have very little empathy or understanding of how others can have very different fitness, strength, skills, etc.
2. Or some people are aware of that but like to point out that they're 'better' by posing a loaded question because they need to feel better about themselves..
I get up hills with a 32/18 SS with magic carpet wheels. Does that make me as awesome as you?
I guess not as I would be spinning out on the down hills 😆
right time for some more willy waving, I did my local loop yesterday and got all of it with 39t up front 🙂
Hej. I only said that as a joke. Hence me saying I was knacked, pushed and had fun blasting down the hill on the other side. It is a bit funny that loads of people think this is willy waving. I am rubbish at spinning and said that several times. I was honestly interested if there were any folk of this parish that did not see any need for huge ranges at the back.
Admit it you've got one of those electric assist bikes haven't you .
Best post since glupton's "yes it's a singlespeed eat my dust" post.
Where would I get one of these dinner plate cassettes?
GEDA - MemberHej. I only said that as a joke. Hence me saying I was knacked, pushed and had fun blasting down the hill on the other side. It is a bit funny that loads of people think this is willy waving. I am rubbish at spinning and said that several times. I was honestly interested if there were any folk of this parish that did not see any need for huge ranges at the back
You're taking all our replies far too seriously 🙂
I'm just a cheapskate who does not like being sold stuff I don't need
Hi
Lots of points raised, I found I changed my gearing as I got fitter.
I now run on my full suss anthem x 29er 1 by 10 32 rear 34 oval up front.
I've ridden all over and not found a hill I can't make it up.
Just keep getting fitter and change as you go.
Stop the thread, chiefgrooveguru has won!
XX1 1x11 etc is not for everyone. It's a drivetrain option which suits a certain kind of rider.
Some of us are awesome* and take our bikes into the mountains.
*I know because Strava says so 8)
[i]Gratuitous top of a Munro pic by messiah.[/i]
I tried a 1x9(30x11-34) and it was not low enough for where I ride; although it's what I run on my winter/forest hardtail as its fine in the winter when the mountains are covered in snow and the forests are inches deep in mud so none of the tough techy climbs are properly rideable anyway (unless frosty/frozen... 8) ).
XX1 32x42 is not as low as 22x36 but its low enough for my awesome legs to get me up the same climbs I used to use lower gears for; but I do have to work a bit harder. But thats okay because I hate front mechs and will put up with many inconveniences not to run one (I used to have a Hammerschmidt 8) )
"I hate front mechs"
Why do people hate front mechs?
I prefer them to rear mechs. They weigh nothing, cost nothing, are indestructible, dont snap off when you hit a rock and most important of all - they are immune to grotty cable syndrome. They basically last the lifetime of a bike with sod all maintenance. They're a bit like your mum - always there to help without requiring anything in return.
Some people say they love the "simplicity" of 10 speed. Personally I've never found my extra gears particularly confusing but I suppose I can see how some people might struggle with the big numbers or second lever to operate.
As has been said before "everyone's different"
1. They make your chain come off; it's what they and the ramps/pins/short-teeth are designed to do. I hate it when my chain comes of on a descent or on a nadgy techy bit of trail (usually causing my nads or knee to strike something hard and be sore for a few weeks). Even on my road bike the chain sometimes comes off... hatefull things.
2. In the clag the low-swing front-mech design is a handy shelf to collect mud, this then stops the mech from working as the mud sits in the mechanism preventing the chain from dropping into the granny ring (very frequent where I ride due to the mud... did I mention the mud and riding in it?). Since the chain won't drop into the granny ring as expected your no longer in a position to force the move in the middle ring because you backed off power to change gear... grrrrr. Much swearing and then a re-start required wheras without the front mech and with reduced risk of the chain coming off you just have to MTFU and make the move.
3. Where your front mech shifter used to be is the best place for a reverb or other dropper-post lever.
4. Big chainrings... I haven't used one for years as I'm not interested in going fast on the road or on smooth fireroads.
sounds like user error to me 😆
Yup 😈
or the fact that you can do most of what you want with 1xsomething 🙂 The fact a multiple front ring setup is designed to move the chain off a ring is the first issue. If you were designing a bike now it wouldn't come into the mix at all. If you didn't have huge amounts of road heritage to copy mountain bikes have been something very different from day 1
I use a 32x34 bottom and I find it hard work. It's ok-ish for a couple of hours but after that my legs are dead. Also on technical climbs it's difficult as you lose the ability to give it that extra kick because your legs are dead. There are lots of climbs which I used to challenge myself on but which are now too difficult. Also, you only have one or two all out attempts in your body, so you are always pushing at the end of a big day.
I am a good climber, but would love a dinner plate cassette. I am looking forward to dropping to a 32x36 bottom gear and hope for lower. I like having a single ring though, so stick with it. It's all a compromise and less compromises are good.
Seriously? Because they also have a job of keeping your chain on. They just don't do it so well because they are designed to move the chain.
Without a front mech, you need some method to keep the chain on the chainring, the devices you posted above are one such example there of.
Been running 1x10 with 32t front, 11-36 cassette, but now looking to go larger cassette as will allow a bigger chainring for same low ratio, gaining more top end gearing.
Haven't had any issues even in Europe on current low ratio, and talking to plenty of other Enduro riders who ride in Europe, the bigger cassette range means you can have a higher top gear due to a larger chainring, rather than a lower bottom gear for the same size chainring.
