1x10 on the cheap
[Closed] 1x10 on the cheap
 bubs
[#7253448]
I am close to pushing the button on a 29er frame and would like to set it up a 1x10. The frame does not have chain guide mounts butI have an old 3x10 groupset kicking about with a clutch mech.
Can I just lose a couple of rings on the chainset and trust the clutch to do its thing or do I need to go down the thick-thin route?
Posted : 08/08/2015 12:00 am
 bubs
Actually, just found the chainreaction 1x10 bundle which looks good value and would mean no need for a bodge.
Posted : 08/08/2015 12:12 am
@bubs.
I've just converted my wifes MTB from 1x10 back to 2x10 so I was going to advertise next week OneUp 42t & 16t sprockets & RAD cage for the clutch rear mech.
You'll need a 11-36t cassette. Its simple to set-up, full details on the OneUp website.
Also I have an Absolute Black Oval 34t thick/thin chainring one ride old.
Email in profile.
Posted : 08/08/2015 6:51 am
All you'll need is a clutch mech and a nw ring and maybe bolt washers or short chainring bolts. Use your existing cassette and chain.
Posted : 08/08/2015 7:23 am
I've got 1x10 on both my regular bikes
1 is done properly with N/W ring and clutch mech.
The other is a normal singlespeed chainring and normal mech.
No issues with chain retention on either. I'm not arguing the N/W and clutch don't help, but on a new-ish drivetrain normal bits work fine. Equally I've been running 1x drivechains since 8speed was the default, it was always rare to drop the chain more than once or twice a ride (although, invariably at a good bit!).
If I were you I'd fit a N/W chainring if you already have a clutch and dont already have a SS chainring, a geared chainring is designed to drop the chain not keep it.
Posted : 08/08/2015 9:32 am
Deore clutch mech and cassette, On one ringmaster fitted to an old pair of hone cranks, Zee shifter does OK for me...
CRC weren't doing their bundles when I bunged my 1x10 setup together, they are pretty good VFM by the looks of it.
Posted : 08/08/2015 10:23 am
If you're wanting to go the expander cog route I'd get a praxis cassette... £90 and you get a 322g cassette and no need to buy things separately.
Posted : 08/08/2015 6:15 pm
