As above I need a 32 tooth chainring suitable for 10 speed chain... I need to get it form CRC as I have some credit. I see there is a hope one for £32 suitable for 9 or 10 speed chains or will any 32tooth 9 speed single ring do?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=40426 ]9 Speed[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=80578 ]10 speed[/url]
I will be using a LG1+ style device with top guide, bottom guide and taco so no bash ring if possible.
Thanks in advance.
E13 is nice. as is renthal.
if its just a single ring that your having then any 9 speed ring will work fine.
the internal spacing of a 10 speed chain is the same as a 9 speed, its only the external spacing that is narrower.
they say that if your having a front mech with 10 speed stuff you should have 10 speed specific chainrings for smoother shifting, but people have used 9 speed ones fine (depending on the set up)
the setup would be...
HG81 11- 36 Cassette
KMC 10 speed Chain
Narrow chain ring bolts
LG1+ style device with upper,lower and taco
Suitable chain ring
I'm currently running...
2x10 M590 32,24 (was 3x10 originally)
HG81 11-34
KMC 10 speed chain
Bash ring
all 10 speed specific.
I would be ditching the left shifter and cables (obviously)
So in summary I can just get the renthal ring and it'll be fine?
Renthal 32t is on sale at CRC, it's about the best of them.
thanks guys...
