1x drop bar options...
[Closed] 1x drop bar options?
[#9620058]
What are there? After sameish range as my 2x tiagra. Commuting every day often off road and the recent wet weather has seized a front cable and it seems the shifter is playing up. Don't mind mixing road with MTB cassettes but the compatibility is a minefield.Dont mind SRAM or Shimano but would like it to work with my mechanical TRP spyres.
Posted : 20/10/2017 8:18 pm
I think options are currently limited to SRAM CX1 if you want matching levers or use a third party brake only lever on the left. I’ve never tried running a Shimano STI with no gear cable, I’d think it might flop a bit?
Posted : 20/10/2017 8:33 pm
I’m running 1x with Shimano hydro brakes and 11 speed. Xt mech with a sram 10-42 cassette.
Using a linderets tanpan to adjust the cable pull. It all works well. A little fiddly to set up but hasn’t needed any adjustments since.
Posted : 20/10/2017 8:37 pm
no surprise that SRAM are ahead of the game compared to Shimano on this. The latter needs tanpans, or limited cassettes, or flat-bar shifters, and so on.
Posted : 20/10/2017 8:48 pm
Bar end lever?
Cheap, works, doesn't tie you into any particular system.
If you want indexing, there's 8-11 speed options.and you can mix and match to your heart's delight.
Posted : 20/10/2017 8:54 pm
Gevenalle. They'll convert TRP Spyres too. I run a NW 38T chainring on a 130 BCD SRAM red carbon road crank.
Posted : 20/10/2017 9:09 pm
It flops if you try and shift with it but otherwise it's absolutely fine to run the left without a cable, braking isn't affected.
[url= https://www.gevenalle.com/shifters/ ]Gevenalle[/url]...
Posted : 20/10/2017 9:11 pm
My all city has 11 speed ultegra hydro with 38 narrow wide front ring and 11-40 rear cassette
And a long cage ultegra rear mech
No adapter things just works as it is
Posted : 20/10/2017 9:37 pm
Orange boy what model is that?
Posted : 21/10/2017 8:05 am
Any Sram levers will work with any Sram MTB mech of the same speed. So, cheapest option would be Apex road levers with something like a GX long cage clutch mech. This would let you run up to 40 on the back. No flopping with Sram levers so you can get a 2x10 levers and keep the innards in or they are quite easy to take out.
Posted : 21/10/2017 8:15 am
