Thinking of fitting a 2.4" On One chunky monkey tyre to my rigid 29er. However I'm 'only' using 719 rims and concerned might be a bit narrow for the tyre. Plan is to run lowish pressure so don't want the tyre coming off the rim at the wrong time....
Any advice appreciated.
got a 2.4 ardent which is huge if you wanna try that first, let me know
I reckon it'd be alright...Aside regular UK riding, I was in the Alps last year running a 719 rim on the front with a Minion 2.5 with no problem. Friend rode 719 front and rear no problem. If you're running low pressures, the narrower rim profile won't support the tyre as well so you more likely to suffer pinch punctures, tyre coming off rim is worse case scenario imo. However, if the Smorgasbord tyres I have are anything to go by, the walls on the Chunky M will be decently thick and better supporting
i`ve just started running 2.4 rubber queens which are more like a 2.7 on mavic f819 rims and they seem fine on my 29er rigid kona unit but with 26" wheels 😆 my attempt at a semi fat bike! running them very low pressures as well.
Cheers for advice. RD - thanks for offer but placing order with on one anyway so going to take a gamble a go for it I think.
Ought to be fine. You might not [i]like [/i]it, but it'll work. Depends largely on how honest the sizes are on the On Ones!
I've got a 2.5 on a Stans Olympic just now, lots of people'll tell you that's madness, but it works really well for the job in hand.
You will be fine, i did a year with 717 and 2.4 Advantages, rolled that off twice but did years with 2.4's on 819's
717s and 2.4 chunky monkeys here and they are fine!
actualy they are flippin ace , grip is outstanding so dont have to worry about getting pressures too low
running with tubes but easily survived a couple of gravity enduros now, iirc on-one recomend 19mm as a minimum so its all gravy
