Trying to shed some weight from the XC bike for reasonable money.
Looking at all my components, it seems my bars at 328gr and my seatpost at 254gr are decent candidates for cheap and effective weight dropping.
It's possible to argue the frame would be easier as the Parkwood 29 coming in about 4.2kg is fairly bulky, but that brings in things like carbon frames and pressfit BB's that isn't really a road i want to go down. Replacing the wheels with much lighter would be a hefty expense, so running what i have with tubeless and decent XC tyres is about the best compromise.
But these carbon bars and seatposts are getting serious consideration for sure.
won't loose much from the seat post but you could loose 120g from the bar. I wouldn't bother with Chinese bars, get something reputable.
I'd much rather have a Pressfit BB than an untested cheap Chinese bar!
For me it would be too much of a lottery for those components. There's probably some that are fine, but I'd think the risk would be greater at that price point.
johnw1984 - MemberI'd much rather have a Pressfit BB than an untested cheap Chinese bar!
Yeah but swapping the frame then makes things complicated like needing headsets, BB's, forks being too short a steerer, etc etc... It can end up being one thing after another to save some weight.
It's not that the Parkwood is bad, it just feels weighty, it's the same weight as my Whyte T130SX but it also feels quite back end heavy.
I was looking and the cassette only would be 20-50gr of saving it's a PG1020, so for the cost of £50 i'm not getting a lot of weight saving..
If it gets too much money, it would be cheaper to just flog the Parkwood and buy a lighter XC bike... So i don't want to be throwing gazillions of £$£$£ at it.
Cotic Solaris frame is about half the weight of the parkwood and has a threaded bb. Look for a decent second hand one of those.
interested - was hovering above the On-One Knuckleballs again yesterday, at £44 incl postage.
Was looking yesterday ADS, nothing at all about.
I certainly have a Solaris WANT in my life too....
If anyone reads and is looking to flog a Solaris in a M possibly an L, i'm your man 🙂
I bought one of the last yellow ones a few weeks ago, it really is a nice bike and feels so light. Although I am comparing that with a commencal meta am, and a ragley blue pig with old coil uturn pikes!!
I was looking on here, eBay and pb at second hand ones and they do come up. You've got a bike now so your not desperate, just keep scanning eBay and wait for one to turn up. Or a wanted ad on here.
4.2kg
Parkwood 29er is 4.2 lb not kg, it's a pretty good weight for the frame and its intended use.
what are your existing wheels? Is there anything in the Superstar wheel clearance +30% off code?
IMO bars and seatpost are last resort-ers for weight saving. On top of which finding light bars for cheap with the right sweep/rise or layback/clamp style for you could be tricky.
I know wheels are a much debated area for weight saving, but IMO the difference is far more noticeable than say the difference in lighter bars. Neither may make you significantly faster, but over the length of a full ride I find lighter wheels feel better. My theory is that because they are pretty much the furthest thing on the bike away from your body's core strength then you really notice the difference in handling.
I know a frame swap throws up a few complications with compatibility, but I'd rather get the bits needed than having to pick bits of carbon/gravel out of my face 🙂
Cotic Solaris sounds like a better bet though. I'd say try to put a bit of money away while you're looking for a second hand one, but if you're anything like me, you'll want to change things yesterday!
If you're looking for a name brand carbon riser bar, I noticed that CRC have Havens for £66
http://www.chainreactioncycles.com/easton-haven-carbon-riser-bar/rp-prod125098
Would save you about 130g
Can't help but think the first thread you start after buying and using these £19.99 bars is "What dentist for smashed front teef".
I'd rather buy a known brand second hand bar than a cheap Chinese one.
WTB ST I25 TCS Rim On El Guapo Rattlesnake Hubs 29 Front 15mm Rear 135mm QR Shimano
Wheels above
Weight 29er: Front 990g, Rear 1.225 kg, Total 2.215 kg
So i could in theory drop 400/500gr from that i guess with spending a few quid... but it's really going to cost ITRO £400 to do that.
I do get that the Parkwood is spot on for it's intended use... but as with many times in life, i'm not sure it's purchased use has or will end up being it's long term use... It's more an XC bike than a trail beater that's needed for this year.
[url= https://www.winstanleysbikes.co.uk/product/57061/Kinesis_UK_Strut_F750_Carbon_Flat_Bar ]Cheap (in relative terms) and light. [/url]
There's a medium Solaris in the classifieds currently
Handlebars are the obvious candidate! 😉
Thanks Lummox.
We have a problem here though...
Weight - 4.9lbs for the 19"
Now assuming the PArkwood is actually 4.2.... but even if it's not and heavier in the L, it's still not going to be any different at all.
Hmmmmmm
Merlin Chosen/Alex wheels - under 1700g, £170 delivered.
I can get this for £175 for cash, he's only 10 mins away from me.
http://www.ebay.co.uk/itm/Cotic-Solaris-Frame-/252830134513?
Which is almost a no-brainer for a test risk. Arguably the S is fractionally too small comparing to my Whyte T130SX, it's 1" less TT length than the Whyte, which is a Medium.
The Parkwood is a bit of a barge and i'd argue too big, it's many many MM more on the TT length.
I'd change bars for feel or a different riding position but not weight. A few hundred grams is nothing. It equates to less water in your bottle, 1 spare inner tube rather than 2, don't wear a softshell, wash the mud off the bike etc....
Can't see a weight on them Core ?
https://www.merlincycles.com/pro-build-chosen-hub-alex-volar-trail-wheels-29-82077.html
+1 On One bars
I've both the 747mm softs on my HT and the 777mm hards on my FS.
Cheap, light, strong - rare to have all three.
Looking at those wheels, I think you could swap the rims for some KOM i25s. ERD is close enough that you should be able to reuse spokes and you'd lose something like half a pound for about £120.
[url= https://www.wtb.com/products/st ]st[/url]
[url= https://www.wtb.com/products/kom ]kom[/url]
swanny853 - MemberLooking at those wheels, I think you could swap the rims for some KOM i25s. ERD is close enough that you should be able to reuse spokes and you'd lose something like half a pound for about £120.
st
kom
That's getting into wheel building insanity which is deffo above my pay grade there.
Re the Solaris frame, is it not in fact heavier than the Parkwood (Cotic claims 4.9lb), as you'd expect from a steel frame?
Anyway, just to throw a spanner in the works, what tyres are you running? EDIT - ignore that, you've said already you're going to put lightweight tyres on.
The wheels might be a good part to upgrade if this is for XC race days, then you won't have to faff swapping tyres, just switch wheels over.
For XC stuff on the 29er i'm running Rapid Robs in tubeless. 2.25 and seem to be about 790gr according to a quick google.
The only problem with spare wheels discussions is that i've already got a 2nd set of wheels for the 29er along with a Whyte T130 and also spare wheels for that too ! It's starting to get ridiculous to have 5 sets of wheels then !
It's more for the White Roads 100 mile and the SDW double, rather than flat out XC racing... i'm never going to reach the XC whippet status as it stands, but if i can make the bike lighter for reasonable money then i'm up for it.
You'd be alright, I swapped some rims a while back:
-buy Roger Musson book
-tape new rim to old rim with spoke holes line up
-untape, realign rim so angled spoke holes line up the right way, re tape
-move spokes/nipples over giving a quick clean as you go
-them tension according to book
-build more wheels because it's addictive, thereby cancelling out any cost saving
If you want the building I'll do it for beer money (think you're not far away?).
But in reality I think this is probably going to yield the quickest results. Just pick up something uncool off ebay (Focus, Canyon, Cube, etc)
If it feels back heavy that's probably a geometry thing, you want something longer and lower up front to get your weight over the front wheel.
fwiw..29er frames I've had...
Parkwood - 1800g
Pinnacle Ramin - 1500g
Norco Team (carbon XC) 1250g
Steel in my experience is 2kg+ but its better because it looks nice 🙂
You could probably get a Ramin frame on ebay for < 100 ?
Basically swapping frames doesn't save as much as you'd think.
Hmmmm. It's all interesting isn't it... Well, it is to me anyway.
It seems like you can get say 400gr here from one bit, like the frame for example.... then 400gr from the wheels.... then 400gr from the finishing kit.... 400gr from the drivetrain.... But getting 1kg from the lot is quite tough...
Clearly i can throw £3000 at it and get a super lightweigh XC dream machine... But i'm not in a position to do that and don't really feel it would be the right choice anyway.
I'm probably going to stick today with the first plan then which is some carbon bars (probably the On-One Knuckleballs from above) and a cheap carbon seatpost, as i already need a seatpost anyway due to the other one being creaky as it is.
Thanks for all the thoughts/ideas though gents... very much appreciated.
Second hand big brand ones off here. £20-30.
Worked for me, wife and kids
I use cheap Chinese carbon on lots of my bikes and have never had a problem.
630mm 130g flat bars on both my fat bikes with nearly 10000 miles between them, I think they were about £13 each.
As with anything carbon, just give them a good test before you ride them.
Lock on grips?
Get rid, superstar silicones.
Look at the stem too.
On my first weight weenie campaign on a budget I shed a ridiculous amount of weight changing a Thomson stem with steel bolts, lock on ODI Grips and an Easton EA70 bar to MT Zoom flat carbon bars, KCNC Wing Stem and ESI Silicone grips.
But a back heavy bike has a heavy rear wheel and cassette tbh
What cranks are on it? Some of the lower range stuff is a serious anchor in the middle of a bike
First rule of weight loss purchases though... always weigh the part you are replacing before replacing with a known weighted item.
£18 Chinese carbon bar and no issues used on full suss. Also carbon saddle no issues, but my back side might disagree
Cassette isn't that heavy @ 395Gr
Cranks are Raceface Affect double @ 578Gr without BB weight
The single i've also got for non climby days is a Raceface Ride which is obviously lighter and i also get the lack of front mech, cabling and shifter... But there are certain rides where the last click is required 🙂
Considering the ride in question is for the SDW double, i'm going to be keeping the smaller ring and mech/shifter.
Parkwood is not exactly heavy. For what it is capable of and the price I think it's pretty decent.
Wheels, tyres, forks. Anything else is small rewards for big £ or dubious quality.
Mt Zoom bar will save you 200gr, seatpost is trickier but a KCNC Ti pro will save 80gr or so. KCNC SC Wing stem (as above) is also very light and I've run them on a couple of bikes for years with no problems.
But the best weight saving moves I ever made were always wheels. Hope Pro3/Crests on one bike and ZTR 3.30/Crests on another (with KCNC rotors, tubeless and relatively light tyres). Got both these wheelsets in sales for £300 each.
Lighter wheels, switch to 1X if you haven't already.
Seatposts usually don't make a big difference weight-wise (but some carbon ones are bendier so might be more confortable). You can save some weight with the handlebar, but I wouldn't bother with a Chinese one.
Oh and that 4.2kg typo... bit of a facepalm. You really wouldn't wanna ride a 4.2 kg frame 🙂
You can lose a load of weight by taking the springs and dampers out from inside your forks.
Wheels at that sort of money are just not in the discussion right now. If Merlin had them a few months back when i was buying a spare rear i'd have jumped on it, but i ended up with a Mavic Crossride as my spare, along with the i25 as my others... it's one of them two really only. There's only so many wheels i can justifty and 4 sets is enough.
sell a set then 🙂
Problem with that is... because of some of the crazy cheap wheels about these days, my current wheels are worth about £4.01
Take a dremel to the inside of your seatpost to thin it out. Ever noticed that expensive seatposts are just thinner and hence lighter.
I think the KCNC Ti seatpost mentioned above has an 85kg weight limit.
I fancied treating my FSR to some nice finishing kit & swapped out the branded Specialized stuff with KCNC bits. It was mainly a vanity purchase, but I also figured it would be nice to save a bit of weight.
Ahem. I barely saved anything, weight-wise. The Specialized finishing kit was either pretty light to begin with or weight saving on finishing kit isn't really worth pursuing unless you have cut weight everywhere else, or you know that your stuff is particularly heavy.
Ok, I'll be the the alter ego here. I am running a cheap carbon.
I'd like to stress at this point, I'm the kind of rider who's wheels never leave the ground, I'm also 90kgs.
I'm running one of these bars with no issues so far and have been for about 9 months. Cost me about £19 on ebay, and I have to admit I am happy with it, its light and so far, strong. I have the 680mm fitted and a 720mm one to change to when I go bike packing. I'm slightly nervous of adding another 4kgs to a stressed bar, but I'll be trialing it before I go to Belgium in August.
[url] https://www.amazon.co.uk/Fasteam-Mountain-handlebar-bicycle-Seatpost/dp/B01H76OU2S [/url]
