Just putting one of these together.
I have an M4 180mm caliper. Will this be ok? It fits but will it break it?
Break it - how? I've been running a 180 on the rear of my 456c for 4 months now - no problems..
I didn't think it would be an issue but never harms to check 😀
Sorry for the thread hi jack Mugboo, but does the C456 have the caliper mounted in the rear triangle or in the normal place?
Many Thanks
Phil
Standard is inside the triangle, but you can get different dropouts to mount them in the usual position.
Ah ok, thanks for that.
I was intending on using a V2 with a Superstar 183mm floating rotor, I take it this will fit?
Again sorry for the hijack Mugboo
180 mono4 mounted in the inside of stays here. It's been fine, but bleeding it in situ is a pain as the bleed nipple is at the bottom of the calliper with the bike upright
The M4 180 fits inside. As above, a different dropout is available if it's a problem.
I managed to fit Avid 185mm rotor in the end, but very tight.
It was a pain and I needed the Avid adapter. The shimano one I was trying to use caused many a harsh word shouted in the garage. Got the alternative drop out from On-One, but didnt need it in the end.
