180 183mm rotors qu...
[Closed] 180 183mm rotors question
[#2668769]
I'm running Hope X2 spaced with 183mm brackets. I'm after some superlightweight rotors which I can only find in 180mm.
Will I be okay with these? Or will it cause uneven pad wear???
Posted : 16/04/2011 10:12 pm
1.5 mmof the top of the pad wont contact with it but you can get away with it. If you run avids you can take out some lower spacers but this is not an option with hope
Posted : 16/04/2011 10:15 pm
Cool, cheers man!
Posted : 16/04/2011 10:24 pm
