What size On one 456 do you reckon I should be looking at? Im 6ft with a 33" inside leg.
Your the same size as me, and I'm happy with the 18".
I'm 6'2" and am happy on an 18"
I'm 6ft and had an 18" was fine for me.
I just bought an 18". Havn't built it up yet but measured it against my Large Scott scale and its basically identical! So i would say 18"
im 6 foot with 33" inside leg and ride a normal white inbred in a 20" and i find it tooo big to throw around but comfy for all day rides!
TBH? 19" would be ideal with a halfway toptube. 18" otherwise.
Mine's a 20" mate. You can come and give it a try if you're allowed away from the nest for more than 5 mins 😀
I'm 6'1" and ride an 18". It feels a little bit short on the top tube and the shortest stem I can comfortably run is 90mm, and that's when I'm running a layback seatpost. I'd be keen to try an 20" and run it with a shorter stem.
In your case I'd probably go for an 18" though.
6'3" on a 20" fit is perfect, had an 18" inbred a while ago and
found it too cramped.
Mine's a 20" with a whole heap of seatpost out I'm 6'2 with 33 inside leg... it is set up for xc though
18" is most common size on-one sell
6'1" here on an 18" - it's never felt too small.
I use an 80mm stem and a layback post. But then I use a layback post on all my bikes, road or mountain.
6ft, 33/34 inseam, and both my Inbreds are 18" with 70mm stem and they feel perfect to me.
It's an 18" ... trust me.
The same frame is better (for a 6 footer) in the 29 version.
My fastest laps at MM this w/end were on the 29er On-One and I'm 5ft 10.5.
Try it first before dimissing it!
Tim
6 ft 2, 33" leg riding a 20" with 80mm stem.
6'2", 34" leg riding 18" with 75mm stem.
