17. 5 or 19?
[Closed] 17. 5 or 19?
[#4344551]
Hi there,
Sorry if this is a neewbie question or has been asked before.
I am 178 cm tall and am looking to buy a 2012 Core 26.5
The bike shop has two sizes available, 19" for people 178 cm and taller, and a 17.5" frame for people up to 178cm tall.
Is is better to have a smaller frame for more manoveribilty on the trails?
Any opinions or advice would be great, I think an inch and a half would make a difference...
thanks 🙂
Posted : 09/09/2012 2:12 pm
17.5 sounds spot on IMHO.
Posted : 09/09/2012 2:14 pm
Try both but assuming thats not possible, smaller is usually better especially if you value your soft bits. My last 2 bikes have been 18inch and I'm 185cm.
Posted : 09/09/2012 2:15 pm
 LMT
Need to sit on the bike, and see how it feels, reach standover etc ethier or both might not quite fit.
Posted : 09/09/2012 2:16 pm
 mboy
It's the Top Tube length that's most important to be honest, and there's only 15mm in them. Also depends on your proportions...
Anyway... I'm 1m80 and ride a 17.5" Genesis Altitude. I went for the 17.5 over the 19 cos I've got slightly longer legs and a shorter torso but also cos I prefer a slightly smaller bike with a longer stem. I could happily ride a 19 though with a shorter stem, but I prefer the handling of the smaller frame.
Posted : 09/09/2012 2:19 pm
It's a hard one. The 19" probably lends itself better to a short stem, which may be better for you.
But then, it depends on the frame, the toptube might be long enough for you to have a short stem anyway.
FWIW I stepped down from a 19" with a 50mm stem to a 17.5" and after much experimentation I'm running a 80mm stem on it and it feels perfect.
Best to try if you can.
Posted : 09/09/2012 2:20 pm
What do you ride now? And how does it fit you?
Posted : 09/09/2012 2:27 pm
Thanks everyone
Posted : 09/09/2012 2:28 pm
You might be happier with the larger frame and a slightly shorter stem...
basically what Mackem said.
Posted : 09/09/2012 6:05 pm
