I need some for a new 1x10 build for my daughter.
Only ones I've seen so far are XT for £90 (no rings).
Any others I've missed?
[I don't need rings, just the arms]
GX Eagle with a 32t ring is about £90 too 🙂
[it's going to have a 30t NW ring]
the Thorn could work, ta... square taper though 🙄
Hope. Amazing quality.
Zee come in 165
I got some old xtr m970 165mm a few years ago off eBay cheaply
Have hopes in 165mm. Like them but the installation/removal process is quite involving.
Worth having a look for the DMR Axe cranks. I've got a pair in 165mm and they seem very good. I came from XTR and there is nothing I can tell that is different between the DMR and the XTR. Well priced too
Stuck some Shimano M8000s on the build for my daughter with a 30t ring
http://www.chainreactioncycles.com/shimano-alivio-t4060-9-speed-triple-chainset/rp-prod119950
Or stick a wanted listing on here. Over the years we’ve bought a couple of sets off here for 25 ish notes. Wouldn’t be concerned about going square taper, they often last longer in this house. My White Industry s are square and my fav cranks. Those Thorns look pretty good. I put 150mm on James Bike when he was 8-9 ish and they were ideal, a great way to start them right.
I ended up going with the 165 Zee when faced with the same issue. Didn't give a thought to square taper at the time.
Raceface chester come in 165mm but you need a crank puller to remove them
Zee, someones selling oem ones cheap on ebay at the moment
