15mm through hub be...
[Closed] 15mm through hub bearing query
[#3819416]
I have a 15mm through hub that has gone a little wobbly. On the traditional hubs I would tighten up the bearings. I don't know how to do this on the 15mm. Any advice?
Posted : 29/03/2012 11:11 am
My 15mm AM classic hub still requires tightening up against the bearings.
Posted : 29/03/2012 11:26 am
Thanks, but it doesn't appear to be your standard cone spanner technique?
Posted : 29/03/2012 11:37 am
you're sure it's a cup and cone hub?
Posted : 29/03/2012 11:39 am
[url= http://amclassic.com/documents/help/2009_edited/15mmretrofit09.pdf ]From the AM classic destructions....[/url]
Thread the 22mm adjusting nut with dust
seal attached onto the end of the 15mm
thru-axle and tighten with a wrench. Tighten
the adjusting nut until there is no play and
back off one quarter rotation.
of course yours are likely to be different, but I doubt radically so.
Posted : 29/03/2012 11:43 am
Thanks Sam, That looks good. I'll have a look this evening.
Posted : 29/03/2012 11:47 am
