15mm maxle qr repla...
[Closed] 15mm maxle qr replacement
[#8475841]
Hi all, so today I broke my maxle, specifically the small metal rod tgat holds the qr lever on. So, has anyone used the stealth version yet? Or the Mt zoom thru axle? I fancy a non qr version and these seem to be best options? Cheers, chris
Posted : 29/04/2017 5:58 pm
 m0rk
I did it a few weeks ago, and picked up a stealth on ebay from taiwan. http://www.ebay.co.uk/itm/222423316968
It was about the cheapest place I could find, and I had it inside a week
All good so far
Posted : 29/04/2017 6:00 pm
Cheers! I'm thinking that with no moving parts it should be bombproof! As long as it isn't over tight
Posted : 29/04/2017 6:21 pm
Even better, it's 28 quid at Evans
Posted : 29/04/2017 6:25 pm
As s side note, is there any reason I can't use it still, but tighten by screwing it in? Or will it just work loose?
Posted : 29/04/2017 6:59 pm
I have a maxle stealth (the non qr thing - which I think is the one called the stealth)
Pros it does not have that horrid flimsy end that gets all chewed up.
Cons it can bind in the fork and need a little 'welly' to loosen.
I would only use a proper 6mm Allen key. They are hollow so you could easily lose a 4->6mm Allen key adapter inside it.
I've had mine a month or two. Like it much more than the qr thing
Posted : 29/04/2017 7:34 pm
The binding thing could be overcome with a bit of copper grease maybe?
Posted : 29/04/2017 8:02 pm
