15mm maxel - how ti...
[Closed] 15mm maxel - how tight?
[#2623121]
New Sid forks and AM classic hub, seems like I can screw axel in all the way and then qr isn't as tight to do up as a "regular" qr hub. Is this just how it is? I've never had a 15mm setup before.
Posted : 02/04/2011 7:05 am
Open the lever to take tension off it, and you'll find a 2.5mm allen key fitting in the end, nip it up a click or two.
Posted : 02/04/2011 7:41 am
thanks. That sounds like exactly what is required.
Posted : 02/04/2011 8:38 am
