15mm axle & spa...
[Closed] 15mm axle & spacers
[#1303956]
Is there any real disadvantage to running a 20mm hub on a 15mm axle using a conversion kit? Will there be a little bit of play or will it be too small to notice? Should I just shell out for some proper 15mm hubs?
Cheers.
Posted : 08/02/2010 12:12 am
What hub? If there's an official conversion kit available then there shouldn't be any problem(Hope,for one,use the same hub shell and bearings with different adaptors to convert between standards).
Posted : 08/02/2010 8:35 am
