15mm axle hub qr fo...
[Closed] 15mm axle hub qr fork?
[#5637702]
http://www.ebay.co.uk/itm/Mountain-Bike-15mm-Thru-Axle-to-Standard-5mm-Quick-Release-Wheel-Adapter-/25103161488?pt=Cycling_Parts_Accessories&hash=item3a75206910
Hi all
Looking at a new wheelset that has 15mm through axle hubs that cannot be adapted and wondered about the above adapter for the qr skewer fork I currently have.
Would using the adapter mean I would get the stiffness benefits of running the 15mm through axle?
Posted : 26/10/2013 8:40 pm
 cp
Your link is just to a load of QR listings.
This is what you need. It goes in the hub shell, and then the QR runs through this adaptor
http://www.chainreactioncycles.com/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192
Posted : 26/10/2013 9:32 pm
Excellent stuff, almost identical to what I was looking at.
http://www.ebay.co.uk/itm/Mountain-Bike-15mm-Thru-Axle-to-Standard-5mm-Quick-Release-Wheel-Adapter-/251073161488?pt=Cycling_Parts_Accessories&hash=item3a75206910
Any idea if the nukeproof one would work with shimano hubs and would it offer the rigidity of the 15mm axle or qr?
Posted : 26/10/2013 10:40 pm
Bump
Posted : 27/10/2013 8:34 am
maybe, £15 so worth a go, probably depends on the fork
edit - the way the world is go for a hub that can be adapted to take QR/15/20mm it will save you cash in the long run.
Posted : 27/10/2013 8:36 am
Surely the fact that you'll still have a 5mm rod holding it all together means it'll be no stiffer than normal? If you want something stiffer (and future proof) run something like a superstar switch hub that can do qr/15/20 (as mentioned above) and run it with 9mm qrs.
Posted : 27/10/2013 8:58 am
