I have a 142x12mm SLX freehub that I need to remove. It seems to need a 15mm allen key to remove it, but I can't seem to find one anywhere. Even tried the LBS, but they don't have one either.
Anyone got any ideas?
Try a 10 and a 5 together, might work....
Any good motor factors should have them.
As per Druidh, or you could go for a hex socket?
Edit: Probably be too wide, though.
Fits Yamaha xt660s among get others.
If near Berks I have several.
+1 for ebay
I bodged it last time, think i clamped a bolt in the vice with the right sized head sticking out and used that
Oh I never thought of checking ebay! Thanks for that - I've ordered one from there and will ring the motor factors tomorrow to see if I can get one same day. May even try to get a 14mm and a 16mm for future weird size events.
Thanks all.
I yhink i have a radiator valve core wrench that is about 15mm and you get them in bandq
Same as Ash. I used a 15mm bolt in a vice, dropped the wheel on to it and span the wheel. Came off easy.
Well the motor factors were pretty useless. I'll pop along to b&q or screwfix later to look for a radiator valve wrench and some hex bolts
