150mm rct3 pike to ...
[Closed] 150mm rct3 pike to 160mm?
[#7299547]
as per title, can u take a 150mm pike rct3 solo to 160mm just by changing air spring or so I need a new damper as well?
Posted : 30/08/2015 3:34 pm
 al
Just need a longer air shaft, or one of those extender things someone makes.
Posted : 30/08/2015 4:06 pm
It's an easy job, and if you're interested I've got a nearly new (removed after 1 ride) 160mm shaft for 26"
Posted : 30/08/2015 4:15 pm
Cheers. Have the air spring, but just wanted to check on the damper charger before pulling things apart.
Posted : 31/08/2015 9:09 am
You got a link to them please?
Posted : 31/08/2015 9:44 am
