142X12 axel sticky ...
[Closed] 142X12 axel sticky when tightening
[#9829975]
Hive mind help requested.
Got a 142x12 axel'd trek fuel. Spins fine until I put any tension on the lever and then it gets sticky. Used to be ok, not changed anything on it. Maybe didn't wash things after a ride.
What do you reckon most likely cause is? Had a wiggle about and doesn't feel misaligned or unduly gunged up, took the caps off the frame and there's a bearing in there that seems ok and a spacer that looks like it's in the right place.
help!
Posted : 11/02/2018 12:09 pm
mushromed spacer (DT hub?)
seizing bearing in the freehub?
Posted : 11/02/2018 1:18 pm
recently had a problem removing my rear maxle, only just managed to get it out with my hand and discovered it was bent and starting to crack at the start of the threads.
i had noticed the last time i had refitted it it was a bit stiff to get in so i just greased it up a bit. will be having a proper look if i ever find it stiff again.
Posted : 11/02/2018 3:08 pm
