140mm setup
[Closed] 140mm setup
[#696972]
Was thinking of going to 140mm rotors for my HT and was wondering what needs to be done for setup.
Different adaptors surely?
cheers
Posted : 09/07/2009 9:48 pm
Not all calipers can go as small as 140mm.
Posted : 09/07/2009 9:52 pm
You may struggle. 160mm would be a lot easier
Posted : 09/07/2009 10:30 pm
...why?!
Posted : 09/07/2009 10:32 pm
saves weight, better modulation, less likely to **** it on a rock.
as glenh said though, not al callipers go that small, my old XTR one goes to 160mm, think you can use a front 160mm calliper/addapter though, depends on frame clearance as well as there may not be enough clearance arround the dropout fo the caliper.
Posted : 09/07/2009 10:50 pm
