135mm Vs 150mm rear...
[Closed] 135mm Vs 150mm rear drop outs
[#2952083]
Whats the deal then, is 150mm at the rear better than 135? Will my shifting go to pot, will the back end be massively stiffer (missus)?
Any real world experiences out there?
Posted : 16/07/2011 11:35 pm
 GW
shifting will be the same (assuming 83mm BB shell to match the 150mm rear end)
back end no stiffer than a good 135 bolt thru.
rear wheel should be stronger/stiffer but stupid flange spacing means it often isn't.
Posted : 16/07/2011 11:44 pm
What GW said, though I would add that my old 224 had a 73mm bottom bracket and chainline/shifting was still fine.
Posted : 17/07/2011 12:08 am
 jedi
my bottlerocker feels floppy at the back compared to the demo9 🙂
Posted : 17/07/2011 12:29 am
 GW
that's nothing to do with it being 135 tho.
Posted : 17/07/2011 12:53 am
Currently using a 135*12 bolt through. It's a 73mm BB on an intense ss1 where you can swap the rear drop-outs. Sounds like there is not a lot of point. Cheers folks!
Posted : 17/07/2011 9:35 am
