130mm fork recommen...
[Closed] 130mm fork recommendations
[#4742914]
Evening,
Looking for recommendations for a 130mm 15mm axle fork for my ASR5.
Thinking of Revelations (though open to suggestions) but not sure which ones to go for. Is the RCT3 version much of an upgrade over the RLT and has anyone any experience of the 2013 Solo Air against the 2012 Dual Air version?
Also, has anyone seen any good deals on said forks?
Thanks
Doug
Posted : 12/01/2013 6:08 pm
The fox float's going on On-one at the moment are an absolute steel at £300. Shim them down from 150 to 130 and they should be stiffer than the normal 150mm and exactly what you're looking for.
Posted : 12/01/2013 6:10 pm
Cheers, I'd seen those but don't know if you'd miss the external compression adjustment or the fit damper.
Also thinking about the x fusion velvets, anyone any experience of those?
Posted : 13/01/2013 12:22 am
