Whats the difference between 12mm Hope Pro2 Evo end caps - HUB241 and HUB242?
One is listed as 12mm, the other is X12, but whats the width of each one?
I have some on the wheel I just built for a new frame, but theyre about 2or3mm short, and the rotor rubs on the frame
with a 2mm spacer the cassette rubs on the frame
My non drive side (black one) is 16mm
Have I rebuilt the hub wrong?
thanks, guess i need hub242 then
so hub241 should leave a 7mm space on the frame
if anyone has hub242/x12 they can measure, that would be cool, i could get some made up at work
I think mine are 142x12, it's an Orange Alpine Five from about 2014. Which measurements do you need?
just the length of each cap. its probably 16.5 and 20mm
Yep, black one is 20mm and silver one is 16.5mm
Ta muchly
I ground down a M12 nut to 7mm and drilled it out,gonna try the HUB241 caps swapped round and the nut on the end
Otherwise its £20 and wait till xmas for the HUB242
