120mm pikes - How m...
[Closed] 120mm pikes - How many tokens?
 J273
[#7817201]
Ive just converted my 140mm 29er pikes to 120 for my new build.
How many tokens should i be running? and what LSC should i go with as a starting point.
Being only 10.5st am i best to stick with srams recommendation of 3 tokens?
Thanks
Posted : 09/05/2016 3:25 pm
There's different numbers for max amount of tokens depending on the travel and wheelsize
My 140mm 29" came with 2 fitted, I added two more, the max it can take is 5.
I think 120mm 29" takes 4 max.
Posted : 09/05/2016 3:31 pm
I went with the Sram recommnendations when I dropped my 29er Pike from 150mm to 120mm - and I'm very pleased with the results.
I'm one-and-a-bit stone heavier than you though.
Posted : 09/05/2016 3:35 pm
