120mm+ forked, hard...
[Closed] 120mm+ forked, hardtail frame advice needed...
[#2102106]
having been a long term fan of xc bikes, but liking the ability to stuff up a line or too with 120mm+ forks I'm considering a change to something that'll take a longer fork.
I currently have an old Cannondale with 100mm lefty, would like something not too lardy (<4.5lb, so probably alu)and capable of taking a 120-140mm fork.
Also, nothing with silly slack angles, while I'm sure they have their place, it's a bit of a culture shock to someone used to 71deg head angles! 69 would probably be about right (fnarr..) and it'll need to be long in the top tube (24" minimum for a large)
Would need to be cheaply cheap if at all possible (I know, moon on a stick)
any thoughts?
Posted : 19/10/2010 10:28 am
The large Cotic Soul has a 24" top tube, is 4.4lbs and should meet all your criteria except possibly for cheapness.
Posted : 19/10/2010 10:34 am
How about the Kinesis XC120 🙂
Posted : 19/10/2010 10:44 am
I had a mk1 soul before, nice bike, ran it with 100mm fork and it was ace. That was a few years ago when 100mm forks were still considered slightly longer than you need on an xc bike...
I also ran it with a 105mm stem, which in this day is quite long. I'd be concerned that running a longer fork would mean the reach (read: plumb line through BB to horizontal distance to centre of head tube) would decrease. If I were to run a longer fork I'd probably want to run 90-100mm stem at most, meaning the bike would probably feel a bit short.
The maxlight 120 looks good, but is quite short in top tube from what I can tell.
ta
Posted : 19/10/2010 10:54 am
This is nice! Sorry blatant plug!
http://www.singletrackworld.com/forum/topic/fs-cotic-soul-19-frame
Posted : 19/10/2010 11:54 am
Shortcut, thanks, but I think £300 for a used Soul if a bit much.
cheers.
Posted : 19/10/2010 12:15 pm
Make me an offer.
Posted : 19/10/2010 12:24 pm
well, my old one, with new decals and a nice powdercoat went for £170 (I know!), but I feel you're angling for more than that.
Anyway, this is an idea at this stage, I may end up doing something with the 'dale, depends upon approval from the wife...
Posted : 19/10/2010 12:31 pm
I've a 456 I'm thinking of selling in either XC or freeride guises
18" frame
Magura menja forks (130mm)
DT4.2 rims/shimano XT hubs
XT (ish) drivetrain
XT levers, goodridge hoses, XTR callipers (180/160mm rotors)
Nukeproof wide/flat bars
PRO 60mm stem
Thompson elite seatpost
SDG Bel air saddle
double and bash (22-36-gammut bash) gearing, although I'll swap to a tripple if you fancy.
FSA MX headset
Or swap bit out for:
hope XC hubs with mavic EN321 rims (+£30)
Marzocchi z1 RC2 (the orange aniversary ones) and a 20mm front hub with en321 rim. (worth about the same as the Menja's and a normal wheel)
203/185mm rotors (+£30)
Choice of tyres.
£695 ?
Posted : 19/10/2010 1:07 pm
Bought my Dialled PA frame second-hand for £150 as a bit of an experiement a few months back.
I like it and want to get the newer, lighter version so will be selling the current one soon (probably) - if it sounds interesting, make me an offer. 🙂
Posted : 19/10/2010 2:57 pm
[i]would like something not too lardy (<4.5lb, so probably alu)and capable of taking a 120-140mm fork.[/i]
Chameleon.
Posted : 19/10/2010 3:07 pm
 jonb
Carbon 456?
Something from Chumba (HX1?)
Ragley mm bop (I think that's the aluminium one) they were going to do a less burly one too but still might be heavy.
IIRC you can get a standard inbred to take 130mm forks but again it may be too heavy.
Posted : 19/10/2010 4:28 pm
Has anyone got an HX 1, they do look nice
Posted : 19/10/2010 4:31 pm
Just built a cove handjob with 120mm forks and it rides superb
Posted : 19/10/2010 9:01 pm
Nik - slack angles are where its at. Take your old 'dale and stick something obscenely long on it. If you get a fork with adjustable length, you can wind it back down for climbing/traversing.
I've been running 140mm Thors on my Thorn Raven for a year or so and it works a treat.
(and then buy Pimp's Prince Albert)
Posted : 19/10/2010 9:07 pm
yep - Cove Handjob would be perfect for a 120mm fork - can pick them up second hand for between £150-200.
Posted : 19/10/2010 9:22 pm
A bit leftfield, but I've got a Singular Hummingbird (the 69er / 26er) with Magura MD120s on the front. It's *sweet*. I'm sure you could run gears on it as well, if you really wanted - the guides are all there, as is the rear hanger:
[url= http://farm3.static.flickr.com/2760/4492432529_12e7db5576.jp g" target="_blank">http://farm3.static.flickr.com/2760/4492432529_12e7db5576.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/udder/4492432529/ ]Singular Hummingbird[/url] by [url= http://www.flickr.com/people/udder/ ]bent udder[/url], on Flickr
Posted : 19/10/2010 9:36 pm
