120mm 29er forks re...
[Closed] 120mm 29er forks recommendations please
[#4896912]
What would you recommend on a 29 er hard tail for trail duties?
Reba? Which flavour?
Floats? Which flavour?
Other?
Posted : 22/02/2013 8:04 pm
Revelation RCT from CRC at @£290 have to be the best deal at the moment. 140mm but easily reduced to 120mm with the included spacer.
Posted : 22/02/2013 8:20 pm
Not the standard choice but really happy with my new Manitou Tower Pros so far.. light, stiff and plush!
Posted : 22/02/2013 9:46 pm
Considered x fusion forks?
Posted : 22/02/2013 10:15 pm
X-fusion slide or trace?
Posted : 22/02/2013 10:19 pm
I've just got some X Fusion slide 29's, they seem good, done a couple of hundred miles on them now.
Posted : 22/02/2013 10:46 pm
Tower pro
Posted : 22/02/2013 11:21 pm
Hummerliscious - are you running them at 120mm on an ff29 or have I imagined that? If so how does the setup feel as I'm about to build the same thing?
Posted : 22/02/2013 11:36 pm
What do you guys with the X Fusion and Manitou forks do about getting them serviced?
Posted : 22/02/2013 11:40 pm
Manitou are pretty much DIY. The customer service from the states is excellent as well. Loads on the Internet to help.
They do a tuning kit, the first company that I find that knows what they are doing with one will probably get mine for a fine tune
The qr15 is excellent
Posted : 22/02/2013 11:49 pm
X-fusion go back to upgrade.
 dlr
I have some 120mm Tower Pros on my Scandal which transformed it compared to the Sid RCT3's which barely worked. They did add weight but worth it. Only potential issue I have is the ABS has become really noisy when blowing off (s****) especially if you have 4 or more clicks turned on. They werent like that at the start, anyone else get that? Might email CRC
I also picked up a pair of the "cheap" Rev RCT3's mentioned above which I just put on a Horsethief I have built up, first off road ride in a bit so will update later 🙂
Posted : 23/02/2013 10:26 am
IvanDobski - yeah 120mm on the FF29, awesome set up, it feels like a weapon through singletrack and downhill
Posted : 23/02/2013 9:38 pm
