Have got a set of bolt through Mavic Crosslines on a Zesty 314.
Trying to swap over to aPro II Evo wheelset - when I bolt up the rear the rotor rubs on the post mount on the frame but if I slacken it off there is not enough tension and the wheel bearings slap badly.
Am using the correct evo endcaps
The solution seems to be a nds spacer but am at a loss where to find one.
Posted : 30/05/2013 9:13 pm
sure you have the 142 spacers and not the 135 ones?
Posted : 30/05/2013 9:56 pm
