'B' screw.....
Last time I had a head scratcher indexing niggle I changed my cables and made the outer a touch longer at the rear mech and fixed it, whether it was the new cables or a gentler bend entering the mech I'll never know.
- fixed chain length
- new inner cable
- new outer cable
- correct chain direction
- check cable routing
- new mech hanger
- setup as per manual x 34
Seemingly (just about) ‘ok’ in the stand, total crap out on the trails.
Bought a hanger alignment tool, was a little out so sorted that. Still not a massive improvement. Only things left to change are chain (no indication of issues) or the mech itself….. so I took no prisoners with the latter. After 5-10mins of hauling and checking I now have 12 actual fully functional gears! Definitely still a very sensitive setup, but 1 click up or down now does exactly as it should. That was definitely harder work than it should’ve been!
