My do it all/gravel bike currently has Ultegra hydo shifters and med cage rear mech and an 11 - 32 cassette. Would I be able to run an XT rear cassette on this set up.
With my old 105 10 speed set up it was 11/36 with a 9sp XT rear mech.
11spd mtb and road cassette spacing is not the same.
There will be bodges out there, no doubt.
Since when? They use a different freehub but AFAIK the spacing between sprockets are identical.
Are you running 1 or 2 chainrings?
Edit : You'll probably need one of these...
http://www.wolftoothcomponents.com/pages/roadlink-tech-page
I use an XT cassette on my cross bike, just needed a (? 1.8mm ?) spacer as the road cassette was a tad wider.
Thanks Simon - the roadlink looks just the job
No problem. And as qwerty says, you'll need a 1.85mm spacer behind the cassette (they generally come with 11spd road/cross wheels)
32T is supposed to be the max an ultegra mech can take, you'd need an XT mech as well as the cassette.
Edit: See roadlink edit by simon above
<quote>you'd need an XT mech as well as the cassette.</quote>
But just to point out the XT mech won't play nicely with the Ultegra shifters so don't go down this road.
I've just done this with a 105 medium cage derailleur and STI's, an xt 11-40 cassette and a Roadlink. Everything played nicely though I had to reverse the 'B' screw to clear the 40 tooth sprocket.
Maybe- I stretched a 10s 105 to handle an 11-36 (only rated for 28) but that was 1x. Make sure the mech has the capacity.
If not I can recommend the wolf tooth tanpan plus MTB mech approach. As a nice aside if you pair the 11s tanpan with 11s shifters you can run a 10s MTB mech and cassette- currently a useful way for me to get a bit more use out of the old MTB 10s drivetrain.
