11 46 9 speed casse...
[Closed] 11 46 9 speed cassette ?
 nofx
[#11196383]
Is there anywhere in the UK that sells a 11 46 9 speed cassette at a reasonable price? I've traveled the net for hours to no avail 🙄. Any info ( preferably a link) would be gratefully appreciated 😊.
Posted : 17/05/2020 5:45 pm
Didn't exist at the time, even with 10 speed it wasn't until they came up with 'expander' sprockets did longer-range cassettes become a thing. You could try adding an expander sprocket?
Posted : 17/05/2020 5:53 pm
I've never heard of a 9 speed, the ratio jumps would be too big in the low gears. Just swapped my 3 x 9 to a 1 x 11 and enjoying it. I bought:7
11x46 Sunrace cassette
34T shimano SLX chain ring
175mm shimano SLX crank set
Shimano 11 speed chain
SLX 11 speed shifters.
I bought it all brand new from two shops and it came in at £208
Posted : 17/05/2020 6:05 pm
 nofx
My specialized has the 11 46 9 speed.its a sunrace one. I've seen the bolonay ones,but they look a bit suspect to me.
Posted : 17/05/2020 6:19 pm
 kevs
I have a sunrace 11-42 on my cargo bike with 3x9 for massive ratios, seems ok and looks like you can get bigger now
Posted : 17/05/2020 6:21 pm
 nofx
My finances are pretty dire at the mo, due to being off work. The 11t cog is worn,I ordered an 11t for a 9 speed cassette but the shop sent the wrong one out , they sent me a cog for an 11 speed 🙄 I only paid 350 quid for the bike. It needed about 5 hours work to get it running right. The bikes an 08 specialized enduro fsr.
Posted : 17/05/2020 6:35 pm
11 x 42 here
https://www.decathlon.co.uk/mtb-cassette-9s-11x42-id_864439.html
Posted : 17/05/2020 6:56 pm
It's probably cheaper to buy a 10 speed shifter, cassette, chain, chain ring and rear mech but box do 9 speed.
https://www.boxcomponents.com/Box-One-Prime-9-11-50T-Cassette-Black
With a normal 9 speed mech you might struggle with a wide range cassette
Posted : 17/05/2020 7:18 pm
have run a bolany for 7 months on my old turner with the hanger extension that came with it.
Posted : 17/05/2020 8:52 pm
I bought shimano 9 speed 12-36 last year for an old hardtail going 1x.
Pair it with a 30T chaining and it will do what you want for cheap. It's even using a short cage 9 speed xt mech with no problems at all.
https://www.chainreactioncycles.com/mobile/shimano-alivio-hg400-9-speed-mtb-cassette/rp-prod119945
Posted : 17/05/2020 9:01 pm
 nofx
Cheers for replies 😁
Posted : 17/05/2020 10:16 pm
@cartwheels that's a proper bargain...thanks I might buy a couple.
I currently use a Sunrace 40t 9 speed one and it's been great when used with a goat link hanger thing.
It's good to see the trickle down to more modest budgets. 9 speed works and there's no reason not to have the same range of ratio.
It occurred to me that my 9 speed XTR shifter must be at least 20 years old and hasn't missed a beat. It was second hand when it came with a bike. Have knackered plenty of derailleurs in that time of course :oD
9 speed is therefore the ecological choice
Posted : 17/05/2020 11:20 pm
 nofx
https://www.decathlon.co.uk/mtb-cassette-9s-11x42-id_864439.html. Found this. I guess I'll have to have to put more effort into getting it up the hills .
Posted : 18/05/2020 12:30 am
