10th gear - lost it...
[Closed] 10th gear - lost it and would like it back
[#8413243]
I'm sure this should be easy - but I cannot get 10th gear to always be available on my Prophet.
It's a 1x10 setup, all shimano if that makes any difference.
Had it setup ok after building the bike up, but 10th gear has never been available for long.
So what have I done, cleaned the drive train thoroughly and adjusted the higher (or is it lower) limit screw, the result is that it now it shifts constantly between 9th and 10th gear.
Ideally I don't want to start indexing the gears from scratch - again, but if that is the recommendation from the STW gurus then I will, but thought there must be a quick easy fix ?
For some reason I found indexing the gears first time round quite a PITA, so have been reluctant to do it all again and bugger it up completely.
Posted : 22/03/2017 11:29 pm
do it properly, from scratch.
undo the cable and make sure you can get full range from the mech, you may have bent the mech or hanger...
Posted : 22/03/2017 11:49 pm
Is the cable routed onto the rear mech properly? Check the Shimano docs.
Posted : 22/03/2017 11:51 pm
Re-do the whole lot..
Is so easy to do and you will know you have it right.
Posted : 22/03/2017 11:52 pm
I suspect the cable just need tensioning. But as above do it properly, there is a great guide on the park tool website.
http://www.parktool.com/blog/repair-help/rear-derailleur-adjustment#article-section-1
Thanks all.
Cable is routed correctly. All other gears work as they should.
Will release the gear cable and re index the gears from scratch.
Thanks for the park tool link, will read that and will post back here after I've done it.
Posted : 22/03/2017 11:57 pm
Definitely check mech hanger for straightness too. And while you have the cable undone hold the end and then change gear on the shifter a few times, if there is any friction in the cable then stick some new ones on.
Posted : 23/03/2017 7:59 am
Are you sure that the B tension screw is set correctly . If the mech is not quite far enough away from the casette it can rub the bigest sprocket which can stop it going in . I could be totally wrong but not sure whether you class 10th gear as bigest sprocket or smallest . If smallest then ignore me .
Posted : 23/03/2017 2:49 pm
I was assuming 10th to mean smallest, so disconnect the cable and check that you can get it then - if not, adjust the high stop out a little.
Posted : 23/03/2017 2:53 pm
^ and be glad that rapid rise mechs faded into obscurity
(well they did in my world)
Posted : 23/03/2017 3:13 pm
Have you hit it repeatedly with a hammer???
Posted : 23/03/2017 3:55 pm
LOL
Posted : 23/03/2017 4:35 pm
soobalias - Member
Shirley this is one scenario where it would be a benefit...
Posted : 23/03/2017 5:06 pm
