Mine's on its way out. But dont want to replace with the identical DT Swiss one:
I thought I would be able to get something compatible from Superstar etc, but I think those are just 10mm QR upgrades.
Any ideas?
Correct, and they are very substantial and stiff as anything.
No scientific analysis, but I'd expect to get as much clamping force from the SS one as from the fancy DT Swiss jobbie.
Got one of these Am classic ones on my turner flux. No problems so far, after 12 months or so of twice a week use.
http://www.justridingalong.com/parts/bike-components/quick-releases/thru-axle-quick-release.html
Not so sure those are compatible, the DT Swiss one screws directly into the non-drive side drop out on my BLT (it is 10mm x 142mm).
Yours is probably 142 x 12mm in that case? Or 135 x 12mm?
You better ask the distributor if you're not sure as they're not cross-compatible.
I've had Marzocchi (135x12) and Rock Shox (142x12) rear axles and both have been good, if that helps.
Betd do one for intense bikes. I used it to replace a maxle on an orange five. Superstars are a different thread pitch to maxles
Use a Hadley one which is quite nice.
