10mm rear conversio...
[Closed] 10mm rear conversion - Hope Pro 2
[#3699882]
I'm a bit confused about the options here. I currently have standard rear QR and a Hope Pro 2 hub.
I'm thinking about getting a Superstar Components 10mm rear QR, but would obviously need to convert my rear hub.
Hope obviously do the kits, but I guess I will only need the caps, not the bolt through with nuts (which would be superfluous with the Superstar QR).
Do Hope to the caps only? Or is there a good reason for going with the full on bolt through with no QR?
cheers
Posted : 21/02/2012 12:36 pm
From memory the QR axle goes narrow in the middle. In which case you'll need this - http://www.chainreactioncycles.com/Models.aspx?ModelID=18761
Posted : 21/02/2012 12:43 pm
Pro2 EVO hubs just use endcaps, non-EVO need the whole axle & end cap gubbins.
Posted : 21/02/2012 12:45 pm
