10mm rear axle ques...
[Closed] 10mm rear axle question
[#4800557]
Hi guys ,
I have a cannondale prophet with a standard qr rear end , my wheel can take a 10mm axle conversion but will it work with the prophets dropouts ?
Ian
Posted : 26/01/2013 9:56 pm
A normal qr axle is 10mm diameter anyway
Changing from a qr set up to 10mm through axle should work fine
But seems a lot of hassle , what's wrong with your current qr
Posted : 26/01/2013 10:00 pm
My normal qr is only about 5mm so i want to stiffen the rear end up a bit,
I've never seen a regular qr with 10mm diameter ?
Posted : 26/01/2013 10:13 pm
Works just fine... I have 3 bikes that I now run 10 qrs on...
You get a touch more rear end stiffness but it is small... it seats much better and has solved the problem of ghost shifting on one of the bikes... a worth while and cheap mod IMHO
Posted : 26/01/2013 10:15 pm
On a regular QR hub the hub itself rests in the dropouts, not the QR skewer. The dropouts are 10mm. It will work fine.
Posted : 26/01/2013 10:16 pm
The supersatr ones are good and only £7.99.... no black or red at the moment though..
Posted : 26/01/2013 10:17 pm
It's the hub axle itself that's 10mm and its this that should be touching the inside of the drop out and not the qr itself
Posted : 26/01/2013 10:19 pm
If its a pro 2 hub save yourself £10 and just drill it out. I guess its obvious but I didn't realise that the only difference was the axle id!
Posted : 26/01/2013 10:22 pm
Thanks guys,
Mbnut , it's the superstar ones I've been looking at just have to wait till black is back in stock now .
Posted : 26/01/2013 10:42 pm
