10 Speed Cranks wit...
[Closed] 10 Speed Cranks with 9 speed cassette and chain..any issues?
[#4532518]
Anybody used the above, as I want to put a cheep 10 speed crank on the commute bike.
Anybody tried it and had issues with 9 speed chain on 10 speed cranks?
7
Posted : 06/11/2012 7:45 pm
the 9 speed chain will be fine. if you running a 9 speed front mech thatll cause issues.
Posted : 06/11/2012 8:13 pm
9 speed front mech
huh?
Posted : 06/11/2012 8:32 pm
Cage width and pull ratio are 'speed' specific.
PaulD
Posted : 06/11/2012 8:36 pm
I run 9 and 10 speed chains through a 10spd front mech on a 10spd slx chainset. Either chain,not a problem!
I run 9spd xtr shifters,9spd xtr rear mech and a 9 speed cassette and I've had no problems with either type of chain. I have swapped back and forth and through a range of gearo combo's it doesn't seem to make much odds. Its great!
This doesn't mean it will work with any mega9 dynasis mix mash so be careful mixing anything other than what you asked about.
Posted : 06/11/2012 8:39 pm
Death.
Posted : 06/11/2012 8:40 pm
 mrmo
10 spd Chorus chainset, 9spd veloce shifters, 9spd centaur rear mech and 105 front mech. All plays along fine.
Posted : 06/11/2012 8:41 pm
Nope, sorry. Forgot. It's fine. That's what I've had on my Em Tee Bee for the last 4 months - 10 speed XT double, 9 speed SRAM chain and cassette. Current typing performance suggests no resultant early onset death.
Posted : 06/11/2012 8:43 pm
Thanks all.
Sounds good. I'll be keeping the triple shifter and 9 speed mech just bodging the high and low settings (works a treat with the Middleburn duo I run on the hard tail)so we'll see 🙂
Posted : 06/11/2012 8:44 pm
 nuke
fwiw I've been using a 10-speed double front mech with 9-speed drivetrain (9-speed shifters/chainset/chain/etc) with no issues for months
RE: the front mech. You can't fit a mega9 front mech to the correct height over a dyna-sys chainset anyways. (as far as the correct distance of the underside of the outer plate/outer chainring teeth is concerned regardless of whether it's direct or band on)
sYs*
Posted : 06/11/2012 9:00 pm
All on a road bike,Nuke?
Posted : 06/11/2012 9:06 pm
I have a 10 Spd XT chainset working with a 9spd XT/SLX set up, including front mech. It works fine for me. It is set up as a double with the big ring removed if that makes any difference regarding the high low settings and indexing.
Posted : 06/11/2012 9:50 pm
10 speed cranks with the rest 9 speed is absolutely fine. But as I said in another thread leave the front mech at the same height it was set at for the 9 speed rings (22-32-44) and don't be tempted to lower it down for the 42T outer (if going for a 3 ring set up).
As far as I am aware the pull ratio on the front is the same for 9 or 10 speed and only the rear is different. So if you have the 10 speed 24-32-42 frong rings then the 10 speed front mech would fit better but the 9 speed one will still work, just don't lower it down or it will hit the middle ring.
Posted : 06/11/2012 10:00 pm
Thanks again, guys, should have made it clear that I am looking at 10 speed cranks as wanting to move to double chainset over the triple for the commute duties.
Posted : 06/11/2012 10:33 pm
if you get a double then get a double specific front mech as it will shift better. But any front shifter should work with it
Posted : 06/11/2012 10:44 pm
Been using 10 speed xt chainset and 9 speed xt mechs with. knc al 9 speed chain for 5 months without a problem.
Posted : 06/11/2012 11:30 pm
X7 10spd double crank on a mix of 9 spd X9, slx front mech and ultegra 10spd chain. All good.
Posted : 07/11/2012 10:24 am
